Sponsored by: Real Truck
95 460 hard to start
Old Aug 6, 2020 | 01:18 PM
Rusty0531's Avatar
Rusty0531
I've got a 95 Winnebago motorhome with 460 in it . It's sat four for 5 months through the winter . when I try to start it I had to crank on it for 25 to 30 minutes before it finally started . I drove it for 5 miles and it ran fine but a couple of days later when I try to start it it had the same issue . A friend of mine said to change the temperature sensor . Do you have any other thoughts about this
Old Aug 6, 2020 | 04:01 PM
Djosbun's Avatar
Djosbun
Spray some starting fluid in the air intake tube. If she starts right up, you will need to check fuel pressure as a starting point.
-- Dave
Old Aug 7, 2020 | 08:33 AM
EDC8008's Avatar
EDC8008
DO NOT USE STARTING FLUID!!!! This is specifically for extreme cold weather in diesels. Too much and burnt valves are the end results, and it can cause other issues as well.
You need to start with the basics; fuel, air, spark. Check/replace your plugs, replace your air filter, check fuel pressure.
TDK08
May 27, 2020 10:10 AM
rhoward
Sep 28, 2014 03:55 PM
babbler
Jan 17, 2010 04:57 PM
roughcreekgang
Apr 11, 2003 10:09 PM
