Vin decode needed.
Aug 5, 2020 | 07:38 PM
Vin decode needed.
Hey guys, it's been a long time. I'm looking at buying what's advertised as a 1975 F600, but it's a 1974 F500. Vin is F50CCT07000, trans code is 4, axle code is F2J. Any help would be greatly appreciated.
Aug 6, 2020 | 10:30 AM
Aug 6, 2020 | 02:52 PM
Engine code C: 330 2bbl MD FT engine.
Does it have a red button on the shifter?
Aug 6, 2020 | 03:05 PM
Yes, it's a two speed Eaton. I was more curious about the trans, as it looks to be a 4sp with overdrive. Solid truck, needs the line from the master too the hydrovac unit, and the carb needs properly tuned.
Aug 6, 2020 | 03:09 PM
It would be unusual to find a 5 speed OD in an F500. There are no 4 speed OD transmissions in these trucks.
Other than the Clark OD, I don't know of other OD transmissions offered.
Shift patterns:
The Transmission Page
Aug 6, 2020 | 05:02 PM
The **** on the shifter which looks original is labeled 1,2,3,4, with reverse under first. In the following pattern.
1 3 OD
R 2 4
Aug 6, 2020 | 05:28 PM
Can't find that one. Stand by, maybe we will get a proper decode.
Aug 10, 2020 | 06:08 PM
Quote:
Originally Posted by
pfogle
F50 = F500 (gas).
C = 330 2V M/D FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
T07000 = 1974.
134" Wheelbase.
T = Candyapple Red.
F501 = F500 (gas), 16000 lbs. GVWR
48: 4 = Black Vinyl / 8 = 81A Standard Cab.
4 = Clark model 280VO 5 Speed Overdrive.
F2J:
F2 = Eaton model 15201 Two Speed Rear Axle // 5.83/8.12 // 15,000 lbs. Rear Axle Capacity.
J = Ford 5,000 lbs. Capacity Front Axle with Power Steering.
16,000 lbs. Gross Vehicle Weight Rating.
482321:
48 = Detroit MI Ford District Sales Office, where the original selling dealer ordered the truck from.
2321 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Aug 10, 2020 | 06:45 PM
Thanks numberdummy! Unfortunately I lost this one for to not having cash in the moment... The search continues.
BRONC-OH
1983 - 2012 Ranger & B-Series
Dec 17, 2015 04:34 PM
rusty7983
May 23, 2007 12:01 AM
75 ford man
Oct 8, 2006 02:55 PM
Titantis
May 2, 2006 11:28 PM
