1978 - 1996 Big Bronco
ECM issues
Old Aug 5, 2020 | 05:02 PM
DWSford's Avatar
DWSford
ECM issues
I’m having transmission troubles and it’s led back to my ECM. My Bronco is a 95 EB 5.8 with a E4OD transmission. It has a part # F5TF 12A650 BYA. Will a F5TF 12A650 YB work. I was told my original is a California emissions and the YB is a standard emissions. Any help would be appreciated. The original issue was when put in drive it would act if you dumped the clutch. Thanks
Old Aug 5, 2020 | 05:44 PM
ford390gashog's Avatar
ford390gashog
No it will not work. Why not just get yours repaired?
Old Aug 5, 2020 | 05:54 PM
DWSford's Avatar
DWSford
Supposedly it has 3 times. Do you know what the difference is. I was told it just wasn’t California emissions
Old Aug 5, 2020 | 06:55 PM
rla2005's Avatar
rla2005
The Powertrain Control Module (PCM) controls the engine and transmission. Have you run the Key On Engine Off (KOEO) tests and Stored Code display?
Old Aug 5, 2020 | 07:01 PM
DWSford's Avatar
DWSford
No I haven’t. I was told it was plug and play.
Necronommicon
Oct 29, 2019 07:24 PM
Jtanner76
Jan 10, 2006 08:05 PM
zempman
Computer Chips & Tuners
Sep 12, 2005 02:45 PM
lparks
Apr 29, 2001 07:27 PM
