2010 stuck on “Built Ford Tough” screen
Read some other posts and I haven’t seen a solution that I haven’t tried. My radio is always stuck on the Built Ford Tough screen, sometime the radio will work for awhile then cut out but none of the displays work.When the radio cuts out it stays quiet for hours and will come back on. I’ve tried checking fuses and disconnecting the battery for a half hour and nothing has worked.
Suggestions?
Suggestions?
I'm probably grasping at straws here, but I read somewhere on this forum (I can't remember where) that there's a somewhat large wiring connector under the dash up above the emergency brake that can be problematic, and has caused some other issues that were alleviated by either wiggling the wires around, or unplugging it and plugging it back in. In either case, if I remember correctly the issue was cause by the way it was secured to it's location, it was secured in such a way that is was putting tension on the wires, what most people did was to pop it off it's securing point and just letting it hang loose. There again, I don't even know if this connector wiring even feeds the components you're having the issues with (hence the grasping at straws), but it wouldn't hurt to give it a little shake to see if that does anything for you.
bf5113
09-27-2006 10:07 AM
