2017 F-250 Dash cracking issues
Old Aug 14, 2020 | 09:45 PM
  #31
OffBalance's Avatar
OffBalance
Originally Posted by Y2KW57
I blame YouTube.
All the self appointed pickup truck pundits who whined about trucks not having "soft touch" materials, while equating the tough hardened plastic that Ford used 20 years ago with "cheap", while pining for "stitching", "cushioning", and "plush" interiors.
Check out their truck review videos. Kids who have never so much as held a 2x4 in their hand, never mind hauled a pallet of them, are running their soft hands along the dashboards while running their mouths about what constitutes quality versus cheap... and enough of these yahoos yammering about it finally convinces the market that soft touch and stitching should be a minimum requirement for a $75,000 truck.
So Ford gave the market back what they wanted.
And now we all have to live with it.
I have a 2000 that has never once been in a garage, nor under a carport, in 20 years. No carpet dash cover, no aluminized windshield foldaway screen, no tint whatsoever on any of the windows, not even factory tint, as it's a chassis cab.
And not one crack in the "cheap looking" factory dash.
The so called truck experts on YouTube ruined a good thing.
Another factor is that manufacturers are being pressured to use recyclable and even biodegradable materials. These tend to have molecular structures that break down with time, heat, oxygen, or UV.
The cloth seats in my '94 Suburban are in perfect condition. As is the plastic dashboard. There is one rear door armrest made of a soft plastic that has started to harden, get shiny and crack. Not bad for having raised a family, carried big dogs, and hauled building materials to build a house. That kind of durability and longevity is what I expect in a truck.
I hope my new Ford will be able to do the same.
Old Aug 15, 2020 | 08:41 AM
  #32
Lin19687's Avatar
Lin19687
Veteran: Navy
What about getting one of those Carpet dash covers? I am sure someone makes on that isn't carpet?
Old Aug 15, 2020 | 08:48 AM
  #33
Chrisd13507's Avatar
Chrisd13507
Yea looking at the mat version... starter decided to take a crap this morning its been iffy for a few weeks now.
Old Aug 15, 2020 | 10:19 AM
  #34
jdk1's Avatar
jdk1
Originally Posted by SMOKEPLOE
The only way leather would crack out like that was that they used vinyl cleaner on it instead of a leather cleaner and restorer. I worked at a Cad/Olds dealer. Our cleaning crew was instructed to use a good quality leather cleaner on all Cads because most of what we sold had leather seats and dash covers. I would talk to the GM and find out what they used to clean and restore on your dash. Then go talk to your lawyer! That dash should last longer than the truck with the right items used on it.
Smokeploe
Man, after working with leather for a number of years, I just can't see that being leather at all. Leather has fibers and those cracks are so clean and "sharp." Really crappy deal. I think an upholstery shop could replace that vinyl, nagahyde, plastic laminated garbage for much less than what the OP looking at spending. He could even pimp it up with some Cayman, ostrich, or rattlesnake (!) skin.
OP, can you remove the section yourself! If so, you could probably remove the covering yourself and get the material of your choice from Tandy and glue it down. You just need to clean it up well, get some leather that's skivved down thin, and take your time. Leather bonds very will with glue. Not sure about the material under that cracked covering though. A good leather man of saddle maker might be interested in the job. Just a thought. Good luck!
Old Aug 15, 2020 | 12:39 PM
  #35
Lin19687's Avatar
Lin19687
Veteran: Navy
Some glues will bleed through true Leather so be careful what you use if you do it yourself
Old Aug 15, 2020 | 02:38 PM
  #36
ZAR2USA's Avatar
ZAR2USA
Get horse hide, nice and thick.
Old Aug 15, 2020 | 10:20 PM
  #37
Anibal Medina's Avatar
Anibal Medina
Here you go is way cheaper https://www.tascaparts.com/oem-parts...OC1kaWVzZWw%3D
Old Aug 16, 2020 | 11:00 AM
  #38
jdk1's Avatar
jdk1
Originally Posted by Anibal Medina
and slightly less than the $5500 guoted by the Ford stealer!
Old Aug 16, 2020 | 11:11 AM
  #39
FishOnOne's Avatar
FishOnOne
That's a shame on two fronts...
1. Fords quality on the current trucks dashboards is unacceptable. I've read about warped dashboards for years now and this is on the hard plastic version that doesn't have the soft touch materials and now the cracking on the padded surface.
2. No at the dealer knows that this piece part is replaceable and wants to replace the entire dashboard. Perhaps Fords part of $1,100 is to cover the part and labor to replace the defective part and not towards the entire dashboard.
Old Aug 16, 2020 | 11:15 AM
  #40
FishOnOne's Avatar
FishOnOne
I blame YouTube.
Ford is having problems with the hard plastic dashboards warping and seams to be affecting a much higher percentage of the trucks than this soft touch material cracking.
Old Aug 17, 2020 | 06:30 AM
  #41
Lin19687's Avatar
Lin19687
Veteran: Navy
Call Ford custo er servi e and ask about warranty specs for this. Would be interesting to see what they say
Old Aug 17, 2020 | 07:25 AM
  #42
George C's Avatar
George C
We own commercial greenhouses. When buying poly covers, cost goes up as UV inhibitors are increased in the plastic mix for longevity. Obviously...their UV inhibitor wasn’t up to snuff in that batch of dashes.
Ford should cover that without question.
Old Aug 17, 2020 | 07:49 AM
  #43
System's Avatar
System
Prolocutor
I agree George. That makes sense and it was likely a batch issue rather than an entire product line issue. If it wasn't, we'd be seeing a lot more posts like this.
OP, and chance you'd consider doing the swap yourself? If I was in your situation, I'd buy it at Tasca and swap it out. Yes, I'd upset that Ford didn't cover it but for $350, I'd get over it so I could forget about it.
heather2872
Mar 20, 2020 07:09 AM
maverick600
Ford Truck Parts for Sale
Jul 6, 2015 09:19 PM
spikinfool05
22
Mar 23, 2015 06:58 PM
powerstroker100
Jul 10, 2014 01:11 PM
EDsurvivor
Aug 14, 2012 01:18 PM
