Engine whistles when I am not accelerating.
Old Aug 4, 2020 | 05:35 AM
Blauberg0214's Avatar
Blauberg0214
F100 I Beam w/ straight 6 (original motor) I can drive for 5 minutes sometimes or for 30 minutes before it happens. Its so random, but it always happen eventually.
The truck has its original straight 6 engine with an aftermarket carburetor. We changed the gaskets on the carburetor and tightened all the hose clamps all around. Still there is a whistle. When I have the truck in idle it is very faint so its difficult to locate when i have the hood up. I assume its a pressure thing but two mechanics in my area can't figure it out and I am new to owning a classic vehicle.
Old Aug 4, 2020 | 06:15 AM
chiefdave's Avatar
chiefdave
A vacuum leak is the likely cause. That brake booster looks new and could be the culprit. Not a lot else to check, carb, intake manifold and distributor advance. The nice thing about these old trucks is that they don't have miles of vacuum hose like the new stuff.
Old Aug 4, 2020 | 07:09 AM
Blauberg0214
Thank you. I will start checking those this week. This is my first classic truck so I will take any advice I can get.
Old Aug 4, 2020 | 10:24 AM
SwampRattFord's Avatar
SwampRattFord
+2 Vacuum. When idling your vac is higher, when you accelerate the vac goes down. Vac goes up whistle does too.
Old Aug 4, 2020 | 10:29 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
“Engine whistles when I am not accelerating.“
Maybe you can pick a harmony part and join in?
Old Aug 4, 2020 | 10:36 AM
robertrpeak's Avatar
robertrpeak
Also check that brake booster valve.
Old Aug 4, 2020 | 10:50 AM
Farnsworth's Avatar
Farnsworth
Disconnect the vacuum line from the booster and see if the whistle goes away. Just member that if you drive it like that, the brakes will be MUCH harder to engage.
Old Aug 4, 2020 | 03:07 PM
6t6merc's Avatar
6t6merc
Try a piece of hose for a stethoscope.
If the noise is very faint you can make your engine compartment quiet by using a second vehicle to supply vacuum by connecting your manifold fitting (engine off) to the other vehicle's intake fitting with a long piece of hose.
Eric
Old Aug 4, 2020 | 05:26 PM
TheMonson's Avatar
TheMonson
Little off topic but you might appreciate this.
Old Aug 4, 2020 | 08:35 PM
RangerMercMan's Avatar
RangerMercMan
The correct way to find a vacuum leak is to spray a flammable substance such as propane from a mini torch (as taught in school) with a hose attached or even easier a hair spray with straw that has flammable on the label. WD40 would work too. The trick is to get in close to your hoses and intake and anywhere else a leak could occur. This includes the brake booster and base of the carb. Do not spray down the throught of the carb as this defeats the purpose of the test. Only spray a tiny amount in as narrow of spray as possible. If there is a sudden increase in engine RPM or smoothness in running you have found your vacuum leak.
SonnyGr
Aug 8, 2020 11:37 PM
Blauberg0214
Aug 8, 2020 05:09 PM
mbaldwin11
31
Aug 17, 2015 11:55 PM
PharmerChris
Oct 18, 2014 10:50 PM
RA81222
1978 - 1996 Big Bronco
Aug 12, 2008 03:50 PM
