Wide molding placement.
Old Aug 6, 2020 | 10:30 PM
Hyperactive460's Avatar
Hyperactive460
Again I agree 100%. I would think this thru very carefully as far as how to attach the clips. Are you at least getting new/repop clips? I would not mess with putting a 40 year old clips on there. Bound to break on you. And when you figure out the hole placement, and get done reilling you need to primer/rust prevent that area very well on both sides. The trim that has the mount studs at least should make their holes easy.
Not sure if the plastic clips went on the truck, then the trim snapped on them or how it got put on at the factory.
Rich I'll be using all new hardware but did plan on using stainless steel rivets for the clips.
taylorbickett5
Dec 22, 2012 10:21 PM
madfoundryguy
Jan 26, 2010 01:37 PM
TruckPuller84
May 2, 2007 01:58 PM
