My brake line that runs from the front to the back of the truck has ruptured. It ruptured about half way back along the frame rail. How difficult is it to remove and replace the brake line? I would guess it's about 5 feet long. Since it runs along the frame rail, you really can't see it.
How difficult it will be is going to be determined by your skill level and what tools you have or need to borrow/rent (tubing bender or using something on hand, flare tool for fittings) . FWIW, brakes are typically one of the simplest systems on a motor vehicle.
