2020 Level
Old Aug 1, 2020 | 10:45 AM
2017-350's Avatar
2017-350
2020 Level
Where is the best place to measure a truck after a level to assure that it is completely level? I just put a kit on mine and feel that the rear may be a tad lower now, although it could be my imagination
Old Aug 1, 2020 | 10:51 AM
h20camper's Avatar
h20camper
Center of hub straight up to edge of fender well?
Old Aug 1, 2020 | 11:05 AM
Mainebucks's Avatar
Mainebucks
Post a picture. We will let you know.
Old Aug 1, 2020 | 11:21 AM
OffBalance's Avatar
OffBalance
Since presumably you added a level kit because you thought it looked better, it is right when your eyes say it's right.
Old Aug 1, 2020 | 12:10 PM
Ding126's Avatar
Ding126
I would of measured from the floor to the top front fender / rear wheel opening well..lining up with center of hubs. before and after
Old Aug 1, 2020 | 01:17 PM
2017-350's Avatar
2017-350
Here’s a pic
Old Aug 1, 2020 | 07:17 PM
2017-350's Avatar
2017-350
I’m trying to get one to post that isn’t sideways. Sorry guys.
Old Aug 1, 2020 | 07:53 PM
jjmoberg's Avatar
jjmoberg
It’s nose high to me.
I personally think that everyone that measures form the ground to the wheel arch is doing it wrong. The only thing that your eye picks up on is the fender gap from top of the tire to the wheel arch. I measure from the top of the tire to the peak of the wheel arch.
My 250 6.2 CCSB with heavy service front suspension had a difference of 2 inch in the wheel gap front to back. I put a 1 inch Daystar spacer in front and have a 1 inch difference now. I didn’t want perfectly level.
But I think a lot of guys doing 2.5” levels with either gas engines, or heavier springs, or both, will end up nose high.
Old Aug 1, 2020 | 08:03 PM
Mainebucks's Avatar
Mainebucks
Looks good to me.
Old Aug 1, 2020 | 10:11 PM
ejb69's Avatar
ejb69
Measuring to the top of the bed rails front and rear is probably the most accurate. Although I don’t see how one could get a pickup to always be level unless you a have air bags. My 2020 F350 seems to sag more under load than my 2016 F250 did. Both of those seem to sag more than my 1999 dodge did. I have pulled the same trailers with all three of them.
Old Aug 1, 2020 | 10:53 PM
Shmingey22's Avatar
Shmingey22
The problem I see is that the hood height is higher then the box rails. What I mean is that the hood line hits the cab about 2-3” higher then the top of the box line leaves the cab. So even if it’s level the front will look higher then the back. I’d personally measure the bottom line of the cab just behind the front wheels and just in front of the rear wheels from the ground up.
Old Aug 2, 2020 | 12:09 PM
Mainebucks's Avatar
Mainebucks
Yup. that's the way to do it.
Old Aug 2, 2020 | 08:07 PM
zeroo's Avatar
zeroo
On level ground just measure the the highest point of fender, this isn’t rocket science.
with ford lowering the 2020’s I’m surprised people have to level them.
Old Aug 2, 2020 | 08:20 PM
Daniel Reinard's Avatar
Daniel Reinard
Level might look different to someone else. What bugs you about the level? Running boards catching your eye? Bed rails? Front to rear fender height? Find out what bugs you about the stance and measure accordingly.
For me true level looks saggy. I would aim for 1/2" rake as measured from fenders.
According to Ford's literature the majority of 2020s are lowered 1/2" in the front and 1" in the rear. It's only marginally (1/2") more level than 2019. My 2020 F350 had 3" rake as measured from the fenders. Still quite a ways off from level. Tremors are about the same. Just taller front and rear.
Old Aug 2, 2020 | 08:44 PM
zeroo's Avatar
zeroo
I’d like to see a comparison of equally suspended 2019 and 2020 fender heights.
