Tpms. New/old
Old Jul 31, 2020 | 05:57 PM
Shawn2017's Avatar
Shawn2017
Tpms. New/old
Ok here it is I replaced my 20s last week with raptor rims and tires left old wheels all together.
put brand new sensors in raptor wheels. I have had what I believed to be reading for theses wheels
til today got the tpms alarm. So I tried to train them both ways. I have psi readings but not right cause I had one wheel with 5 psi in it an was reading 35. Can the truck be reading the other set which is 30 feet away. If so how can I clear them out an set truck to new ones. Help. This is pissing me off. Thank for any an all help
Old Aug 1, 2020 | 08:08 AM
rmccbride's Avatar
rmccbride
So you’re driving around with a tire that has only 5psi in it waiting for the reading to change? Try putting 40psi in all the tires and go for a ride and see if they read right..
Old Aug 1, 2020 | 08:27 AM
Shawn2017's Avatar
Shawn2017
No I have aired them up over 35 psi. Checked them an aired them down an checked. The psi does not move.
Old Aug 1, 2020 | 08:37 AM
rmccbride's Avatar
rmccbride
How far did you drive? It takes a few miles for them to turn on and update.
Old Aug 1, 2020 | 09:24 AM
scott91370's Avatar
scott91370
I agree, air them up slightly higher then drive around.
Old Aug 1, 2020 | 09:58 AM
GlueGuy's Avatar
GlueGuy
I recently had to have a nail removed from the left-front tire. The shop (America's Tire) repaired the tire and also did a rotate/balance. The tech who repaired the tire aired that tire up about 2 PSI lower than the other tech who did the rotate/balance on the other 3.
So when I left the shop, the 2 PSI lower tire still showed at the left-front. About 5 miles down the road, the 2 PSI lower tire "moved" to the left-rear. How about that? It learns as it goes. I'm kind of curious how it does that.
Old Aug 1, 2020 | 12:31 PM
scott91370's Avatar
scott91370
Because each corner has a receiver. The closest sensor to that receiver is what shows on the display.
Old Aug 2, 2020 | 01:42 PM
TJReams's Avatar
TJReams
I did not know this. on earlier versions you had to put the vehicle in learn mode, let the air out of each tire till the horn honked starting with the drivers side front and going clockwise around the truck. I guess I just glossed over that section on my new truck.
TJ
Old Aug 4, 2020 | 10:59 AM
Shawn2017's Avatar
Shawn2017
I get it into learn mode I can’t get the horn to signal on drivers side. Let all air out one time an nothing.
there training mode actually times out so I still fighting with them. Any one done it with forscan thinking that may be next
Old Aug 4, 2020 | 01:02 PM
dlburch's Avatar
dlburch
yes, the tpms sensors can be read 30' away...I got a tire repaired in St. Louis. was sitting in the parking lot watching the tech remount the tire...as he was reinflating it, the low pressure light on the dash went off...I was probably around 40 feet away.
Leidy
6.7L Power Stroke Diesel
Jul 20, 2017 06:51 PM
Merimar1
May 19, 2017 08:14 AM
parkerparkerm
Oct 8, 2012 03:10 PM
SuperDuty93
Oct 26, 2011 06:59 AM
is300wrx
2004 - 2008 F150
Mar 7, 2006 01:20 PM
