Sponsored by: Real Truck
Long Crank Time
Old Jul 31, 2020 | 05:20 PM
glafond's Avatar
glafond
Long Crank Time
original 6.0 jiunk motor died at 180K.
i put a new engine in my truck, everything was great. now at 320K
then... each start, if the truck is siting more than a few hours, is extremely long.
dealership is not finding this issue.
once it starts, it runs fine.
Old Aug 1, 2020 | 10:58 AM
Evan_P's Avatar
Evan_P
Do you have a way to monitor live data from the engine computer? If so I would start by monitoring ICP pressure and IPR duty cycle while cranking. If ICP takes a long time to build up to 500psi while cranking and IPR is maxed out at ~85% you have a internal leak causing oil to bleed down while sitting. If while cranking
gpeade
Mar 26, 2020 03:51 PM
rwallen85
Nov 26, 2015 02:47 PM
94WhiteF250
Feb 29, 2012 08:00 PM
david moore
Sep 10, 2011 12:31 PM
dirty661
Sep 16, 2010 12:26 AM
