351 w won’t start
Old Jul 31, 2020 | 03:23 PM
Joshua Battle's Avatar
Joshua Battle
351 w won’t start
Recently bought a f250. They guy I bought it from said it only worked on the front tank. Well after driving around a couple days i would lose rpms between 30-40 mph. After filling the front tank and driving home I noticed gas was leaking from the rear gas cap. So when I started the truck up again it would run and fire up just fine. But while it was at idle gas was coming out of the rear tank again so I opened the gas cap ( which was dumb ) and the truck shut off and now won’t start I’m no mechanic but all my fuel pump relays are fine and my inertia switch isn’t tripped and I have power going to my fuel pump. I’m not sure how many volts. Any ideas?
Old Aug 11, 2020 | 12:24 PM
john j oliver's Avatar
john j oliver
I am no expert but in thinking about it... check the valve that switches from one tank to the other. it may be going bad and not fully positioning correctly.
Old Aug 11, 2020 | 05:50 PM
torq'ta 5 8's Avatar
torq'ta 5 8
what year, truck?
Part 1 -How to Test the Fuel Pump (Ford 4.9L, 5.0L, 5.8L)
Old Aug 13, 2020 | 06:46 PM
Joshua Battle
It’s a 1996 f250 it turned out to be the fuel pump, now my rear fuel pump does not work so when I’m driving the front pump send fuel to my rear tank and when it gets to full it will then come out the gas cap. So I guess my question is can I bypass the rear tank? How? Will the pressure remain the same and not cause any problems?
Old Aug 13, 2020 | 07:02 PM
torq'ta 5 8
not sure about how to bypass, but replacing your rear with a new FDM(pump), should stop it.
Mikeman
May 29, 2014 01:09 AM
motoxxman
13
Oct 30, 2012 10:21 AM
neil1218
Feb 8, 2011 03:56 PM
koberdave
Dec 16, 2006 10:09 PM
dkchristensen
Oct 17, 2002 12:34 AM
