I replaced both fuel filters on my 05 f350 6.0 along with the fuel pump. I realized the power supply was bad replaced that with a new one. That was 2 weeks ago and truck will crank but will not start it tries but does not. I also drained the water separator replaced the fuel regulator due to the machanic said that was the problem still no start and fuel will not get to the secondary fuel filter housing under the hood. Checked for leaks at connections and filters both pumps are turning on. I loosen the banjo bolts and fuel comes out. The truck got 3/4 tank of fuel in it. I’ve been working on it for 2 weeks with no luck
not sure, but i think i am getting really close to where you are. if my truck sits for more than a few hours,
when i start it, it cranks to the point of failure, in the winter (below 50), then, when i crank it again, it starts.
in the summer, it starts just before the point of failure.
my dealership is clueless.
if you get a fix, please let me know.
likewise.
