Here's the problem. When I close any door, the interior lights stay on. If I then lock it with remote, then the lights go off. The go off when I start the EX. The switches seem fine since the lights go off with a remote and lights go on when opening any door.. They just won't go out unless a remote is used or engine started. I've searched and found no answers. I don't know what else to check.
It probably does. I was doing something on it one time and then went in my garage for easily longer than 15 minutes and they were still on. I might have to time it to see for sure if stays on longer 15 minutes.
I have read about the door latches having a little white button that can fail or be gummed up causing this issue through lack of contact, but here's a couple diagrams anyway. Somewhere there has to be a time-out module or relay controlling this.
