Disabling the Courtesy Timeout Lights?
Old Jan 21, 2014 | 03:01 PM
Lake Rat Jim's Avatar
Lake Rat Jim
I like to do astrophotography, which puts me out in remote areas in the total darkness. The problem I am running into is whenever I open a truck door to get inside to stay warm or retrieve something, the dome lights and parking lights come on. They stay on the whole time the door is open, and for some time afterwards. Surprisingly, even this small amount of light completely ruins night sky exposures, and if I am with a group I get all kinds of choice words directed my way if I open a door. Is there a way to disable this feature when needed, and turn it back on for everyday use?
Old Jan 21, 2014 | 03:28 PM
sandyc's Avatar
sandyc
Good question. I'd like to do the same thing.
Old Jan 21, 2014 | 03:30 PM
SavageNFS's Avatar
SavageNFS
I know Andrew has his dome lights on an upfitter...he'll be able to help when he sees this post.
Old Jan 21, 2014 | 07:50 PM
TRENT310's Avatar
TRENT310
Is the Police vehicle blackout feature still available on these?
Old Jan 21, 2014 | 08:08 PM
darren32's Avatar
darren32
Yes, you should be able to get your dealer to program it
Module Configuration and Parameter Chart
<table border="1" cellspacing="0" cellpadding="3"><tbody><tr><th align="center" valign="bottom">Module </th><th align="center" valign="bottom">Module Address </th><th align="center" valign="bottom">Requires PMI </th><th align="center" valign="bottom">Reprogram/ Flash Capable </th><th align="center" valign="bottom">Requires Adaptive Learning or Calibration </th><th align="center" valign="bottom">Available Programmable Parameters </th></tr><tr><td align="left" valign="top">ABS module </td><td align="center" valign="top">760 </td><td align="center" valign="top">Yes </td><td align="center" valign="top">Yes (with RSC®) </td><td align="left" valign="top">Yes </td><td align="left" valign="top">
  • Front/rear tone rings
  • Interative vehicle dynamics initialization
  • TBC
</td></tr><tr><td align="left" valign="top">Accessory Protocol Interface Module (APIM) </td><td align="center" valign="top">7D0 </td><td align="center" valign="top">Yes </td><td align="center" valign="top">Yes </td><td align="left" valign="top">No </td><td align="left" valign="top">
  • Stereo in pass-through
</td></tr><tr><td align="left" valign="top">Audio Control Module (ACM) </td><td align="center" valign="top">727 </td><td align="center" valign="top">Yes </td><td align="center" valign="top">Yes </td><td align="left" valign="top">No </td><td align="left" valign="top">
  • Clock display (without navigation ACM )
  • PAM (with navigation ACM )
</td></tr><tr><td align="left" valign="top">Auxiliary Heater Control Module (AHCM) </td><td align="center" valign="top">7E3 </td><td align="center" valign="top">No </td><td align="center" valign="top">No </td><td align="left" valign="top">No </td><td align="left" valign="top">None </td></tr><tr><td align="left" valign="top">Body Control Module (BCM) </td><td align="center" valign="top">726 </td><td align="center" valign="top">Yes </td><td align="center" valign="top">Yes </td><td align="left" valign="top">Yes </td><td align="left" valign="top">
  • 2- or 4-door configuration
  • Axle ratio
  • Front turn lamp outage configuration
  • Police dark car feature
  • Smart unlocking
  • Stop and tail lamp outage configuration
  • Rear turn lamp outage configuration
  • Tire placard pressure
  • Tire size
</td></tr></tbody></table>
Old Jan 21, 2014 | 09:48 PM
Lake Rat Jim
Very cool! Thanks a bunch! Rep points coming yer way.
Old Jan 24, 2014 | 01:20 PM
darren32's Avatar
darren32
I was thinking about this one.... since I just noticed you said turn it back on for every day use LOL
Far as I know once they enable the dark car feature, that's it unless you get it programmed back to disabled.
Could you not wire a manual switch in parallel with the door switch? Close the switch and then when you open the door the truck does not know its open. Don't see why that would not work as long as you are not locking and un locking with the key fob. Open the switch and it returns to normal operation.
Only thing I don't know is if it would mess with the anti theft system...
I don't think there is a butt sensor on the drivers side?? Only thing I can think of is maybe if you started the vehicle and the truck said hey the door didn't open, maybe that would set it off. IDK
But it would be really simple to try, attached is the info if you want to give it a shot
Thanks
File Type: pdf
File Type: pdf
File Type: pdf
4wheelfurry
2015 - 2020 F150
May 16, 2018 01:39 PM
Momsey
Escape & Escape Hybrid
Sep 11, 2010 07:06 PM
Secret Agent 069
Nova Scotia
Apr 28, 2008 10:20 AM
sublimecharger68
Garage & Workshop
15
Feb 10, 2007 10:36 AM
wlmgshap
Electrical Systems/Wiring
Mar 20, 2001 11:08 AM
