Window rollers
Old Jul 31, 2020 | 07:53 AM
Sickler1's Avatar
Sickler1
Window rollers
I've been dealing with this problem for about 2 months now. The window rollers keep popping off the window lift channel.i thought it might be the cheap rollers I got off Ebay but ordered new ones threw midfifty and still same problem. All the window parts are new and nothing seems bent.
Any suggestions?
Thanks
Old Jul 31, 2020 | 08:13 AM
big job's Avatar
big job
I just went through this (new glass) my rollers, two dished washers
then the spring flat washer then the lock clip. Spread the dished washers put into the
channel move roller as needed to go into the regulator pin and snap it in its lock clip.
something wrong with your roller picture should be two cupped or dished washers far
left on your picture I only see one ???
Old Jul 31, 2020 | 08:34 AM
Sickler1's Avatar
Sickler1
thanks for the reply, yes there's just that outside plastic lip and 1 metal washer.is there suppose to be 2 metal washers that sandwhich the window lift channel?
Old Jul 31, 2020 | 08:47 AM
Sickler1's Avatar
Sickler1
Old Jul 31, 2020 | 09:07 AM
big job's Avatar
big job
Now plain as day; looks like you have only one outside plastic lip, with two of those,
that is the sandwich that slides along the lift channel. Earlier rollers were steel later
ones made out of plastic they do the same thing. I too, not the first time missing parts. Maybe a regular steel washer smacked with a ball peen hammer to form a dish: nothing to loose > it has to be dished so it will slide freely on the channel. My old habit is if I need two I buy 4 LOL sam
Old Jul 31, 2020 | 09:30 AM
Sickler1's Avatar
Sickler1
I
I have extra rollers so I just took the washers off those to make this.that better?
Old Jul 31, 2020 | 10:01 AM
52 Merc's Avatar
52 Merc
If you have an original channel track, compare it to your new one. I'm guessing there's a difference in the "grab" area of the lip on the edge of the channel. It looks a bit small from my memory. You may need to modify the channel for a better fit to the roller.
Old Jun 13, 2021 | 10:24 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Did this solve your issue? I'm dealing with the same thing now.
Thanks.
I
f-150 on 22's
2004 - 2008 F150
Sep 4, 2007 09:11 AM
ozzy1
Apr 14, 2006 11:17 AM
Cameo
1978 - 1996 Big Bronco
May 27, 2003 11:42 PM
mptruck
Aftermarket Products
May 4, 2002 12:22 AM
