Cab height for late model SDs
Old Jul 30, 2020 | 02:48 PM
7.3F350's Avatar
7.3F350
Greetings TCers.
I sometimes carry a truck camper on an older SD F350 DRW chassis cab. Will likely upgrade to a newer ride before long and making plans for new flatbed.
I found a body builder's guide for 2020 chassis cab, and from reading the specs, it looks like the cabs are now 2" taller than early SDs?!?
For those that used the same truck camper on an older SD, did you find that you lost cab/camper clearance with new truck? Although I'm buying another chassis cab, I'm going to guess the cabs dimensions are the same...
Also: when did Ford start using same cab for F150 and SD?
Old Jul 30, 2020 | 05:44 PM
greenno's Avatar
greenno
FWIW I previously had a 2004 F250SD Super Cab that my 2019 Arctic Fox Camper only sat on a rubber truck bed mat ( approx 1/2" ). Currently have a 2019 Ford F350SD Crew Cab and I only need the same rubber truck bed mat. Both trucks are longbed. I was worried if I would have to raise the camper to fit the truck, but didn't. Good luck.
Old Jul 31, 2020 | 05:58 AM
Bill Tex's Avatar
Bill Tex
Similar for me; had rubber mat with previous truck. 2020 CC is a bit taller, I added 1” structural foam under the rubber mat just to be safe.
Old Jul 31, 2020 | 09:08 AM
crewzer's Avatar
crewzer
Lightbulb
Originally Posted by 7.3F350
...Also: when did Ford start using same cab for F150 and SD?
I believe it was when Ford introduced the all-aluminum body Super Duty in MY2017.
HTH,
Jim / crewzer
Old Jul 31, 2020 | 07:16 PM
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
HTH,
Jim / crewzer
I believe 2017 is correct. Can't say for all camper manufacturers, but I believe it was the 2018 Lance Campers(their model year began 03-01-2017) that they added a basement and higher clearance, along with making the climb into the cab over bed easier for the older folks. On my 96 I have 8" of clearance from cab to the bottom of the cab over. On the 2011, I have nearly the same clearance measured to the top of the cab. Subtract a little from that for the clearance lights that are on the 2011.
Kuboita
Nov 24, 2018 09:12 PM
Dieselborg
Jan 17, 2018 09:50 AM
SD Dually
Oct 7, 2017 11:02 PM
7.3mongo
Oct 25, 2011 06:42 PM
CharGriller
Mar 4, 2009 10:50 PM
