Power Window Slipping.
Old Jul 29, 2020 | 09:19 PM
mrhemi's Avatar
mrhemi
'94 F150 XLT. Drivers side power window started slipping on the way up. Have to help it along by hand. Motor runs fine. Is there some type of clutch that can be repaired or replaced, or do I have to replace the whole regulator?
Old Jul 29, 2020 | 11:45 PM
Mudsport96's Avatar
Mudsport96
There are actually 3 teflon discs in the motor that probably disintegrated.
I put 3 little metric nuts in mine and it works fine.
Old Jul 30, 2020 | 05:17 AM
2dwoods's Avatar
2dwoods
Yes pull the motor put new nylon in ,it has plastic so if someone rolls window up on someone it will break ,I've used nuts before but if you have it apart already just get the plastic ones they work best, drill a hole in the door for 1of the 3 screws holding motor in there's already a dimple there I believe for the drill bit.
Old Jul 30, 2020 | 05:08 PM
jdels's Avatar
jdels
I found nice replacement kits at O reilys for $18. The pucks, a new cover and the grease. Easy fix. Think they were from Dorman.
Old Jul 30, 2020 | 06:18 PM
Thejackalope's Avatar
Thejackalope
RenoHuskerDu
May 4, 2018 10:30 PM
Kelly Aitken
May 6, 2013 02:37 PM
tpd475
1997 - 2003 F150
Sep 13, 2006 12:47 AM
SplashMan
Jan 31, 2002 08:08 PM
