460 Ignition Problem
Old Dec 4, 2000 | 08:47 PM
shortk's Avatar
shortk
My 1987 Class C motorhome on an E-350 chassis with a 460 has developed a problem I cannot identify, but it seems like a timing problem to me. I usually set the cruise control at about 65mph and it runs along quite well, but the last trip I would occasionally get a small backfire, that I could hear, but not feel, just a little "pop". Also, once when passing a line of semi trucks, I kicked it up to about 72mph to get around them and all of a sudden it just starting slowing down. The motor sounded smooth, just no power. I was about to jump in my Ranger I was towing and PUSH the motorhome! It dropped down to about 55, and I fell in behind the truck to let other traffic pass, and it would then accelerate and I passed the truck at about 75 or better after that. Power on the hills has dropped too, but it seems ok sometimes. I first thought it was a fuel problem, but I changed the filter and checked flow out of the fuel line and it looks good. The timing at an idle is fine, the mechanical advance seems to be working, but doesn't the Dura-spark module control timing too? Of all the Fords I've owned, the only problem I've had with a Dura-spark was no spark at all not an intermittant problem like this.
Any help would be appreciated.
Ken
90 Ranger 4X4
91 Explorer 4X4
94 F-150 4X4
87 Ford Moho (ailing)
Old Dec 5, 2000 | 10:34 PM
jakegypsum's Avatar
jakegypsum
Ken, have you tuned the engine up lately? It could possibly be a cracked ignition wire or boot right where the wires go to the plugs. The heat from the exhaust manifold could have dried the wires out. Also check coil. Make sure that there are no cracks in it and that it is sending a blue spark to the plugs. I have had similar problems with wires on my 92' f-250 (351 engine). I have seen the coil act up like this on all of my f-700's at one point or another. 84', 86' 87' & 89'.370 engine. Also check wiring to distributer for chaffing on engine block. Good luck.... Jakegypsum // Ford fleet, soup to nuts.
When the wind is right, you can hear those Chevy's rust..........just listen.
Old Dec 21, 2000 | 05:45 PM
homeonwheels's Avatar
homeonwheels
I had a vacuum leak going to my vacuum advanced that caused a very simular problem....Ran great...would back fire...lost power and slows down. I would take my foot off the gas and then would run fine for a while.
Old Dec 21, 2000 | 07:16 PM
Phillip Guidry's Avatar
Phillip Guidry
Just A note on fuel filters for the 460 cab & chassis models, some models had 2 fuel filters per vehicle. One was the 3 line filter between the fuel pump and carb, and, some had a canister filter between the tank and fuel pump....check very closely for the "extra" filter. Also, the vacuum line tip is a good one....seen that one many times as well.
Phil
Old Dec 22, 2000 | 05:13 PM
deleontow's Avatar
deleontow
I would check your fuel presure with a guage, you may have a fuel pump which can not keep up with the flow at higher rmps.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Dec 28, 2000 | 03:09 AM
xaviar's Avatar
xaviar
Yes Philip, you're right. Ford quit using that canister filter around 1992 or so because of the problems it was causing. No one knew about it to change it. I was told by a Ford dealer to remove the canister filter and just run the inline filter.
Xaviar
Old Dec 31, 2000 | 09:02 PM
xaviar's Avatar
xaviar
[font size="1" color="#FF0000"]LAST EDITED ON 31-Dec-00 AT 10:03 PM (EST)[/font][p]Hi Ken
Can you tell me if your truck is EFI or Carb? If it is EFI, do you have a MAP sensor or MAF sensor? I've been looking for a conversion kit for my truck to MAF. 96 F-250 460/E4OD. I've been told that a few Motorhome Chassis had MAF up till 1994 or so.
Have you ever heard of a MAF conversion kit for the 460?
thx
Xaviar
Old Jan 6, 2001 | 07:35 AM
shami02's Avatar
shami02
You go Xavier, Keep looking for that MAF for our trucks... BTW you didn't answer my last post... Would you email me with the current results of you search I also have a few items to share...
Mike
1995 F-350 460 E4OD
Old Jan 6, 2001 | 12:02 PM
xaviar's Avatar
xaviar
>trucks...
I will not stop till it's found.......lol
>to share...
Just e'd ya this morning.
>Mike
>1995 F-350 460 E4OD
Old Jan 7, 2001 | 01:30 AM
Thudpucker's Avatar
Thudpucker
Tom Dalessandro
Aug 23, 2015 06:50 AM
Brnfree
Jul 5, 2015 01:36 AM
thralldad
Jun 25, 2007 09:28 PM
BobcatGuy
Feb 19, 2007 10:41 AM
doncarter
Feb 10, 2005 02:27 PM
