Seeing if anyone out there has some input or information on a fixed yoke up grade for my c6 from a high boy....
I have a 1975 f150 short bed project I'm working on, I'm putting a 528cu big block in with around 650 hp and 650 tq and I'm wanting to upgrade to 1350 u joints to beef up the drive train. the 9in is easy with unlimited option available... BUT I'm having problems finding information and option available for the c6 with the 10 spline fixed yoke (see image below).
Is the 10 spline on the c6 the same and the np 205 transfer case? because I'm am seeing option for the 1350 upgrade for the transfer
and or is the 4 bolt flange yoke available in the 1350 u joint?
No it is a 2wd short bed the trans just came out of a high boy is is already built to match the engine so planning on reusing it and I'm not going to tear it down to change it over to slip yoke and i need to have a custom drive shaft made either way so will just set it up for the trans.
