Low Power
Old Jul 27, 2020 | 11:38 AM
m_gdavis's Avatar
m_gdavis
Low Power
I have a 2014 F250 6.7l with 54K miles and it has lost a little bit of power over the last year. I pull a 16K 5th wheel and I was able to pull it up my hills at around 58 MPH for the first 4 years. (My old Dodge 5.7l use to do 54 MPH with the same trailer.) Something happen around a year ago where I can only go up the hill now about 50 MPH. I changed the air and fuel filters. The turbo hits 20psi, the temperature never really moves and is good. I get no codes. The engine seems smooth, no hiccups The trailer wheels and hubs are not hot. Without the trailer I can't tell a difference it runs good. The truck does eat a lot of DEF. Seem like I have to fill up every 1500 miles.
Anyone have any ideas on what else it could be?
Thanks
Old Jul 27, 2020 | 04:46 PM
senix's Avatar
senix
when you fill up with def, every 1500 miles, how much are you adding (gallons)?
Old Jul 27, 2020 | 04:59 PM
m_gdavis's Avatar
m_gdavis
2.5 gallons
Old Jul 27, 2020 | 05:52 PM
senix's Avatar
senix
Well your usage if def is fine, quit filling up si often, not needed
Old Jul 27, 2020 | 07:01 PM
senix's Avatar
senix
As far as low power is concerned, absent of any check engine lights or codes that you may be able to pull, I would suggest a trip to the dealer and report the issue, They can, at your expense, run a computer update/check and see if they can come up with an issue.
Bjbeard
May 8, 2018 09:56 AM
rustyranger92
Mar 12, 2017 09:37 PM
frankyh
Jul 28, 2013 06:08 PM
gonnasellit_temp
Mar 31, 2005 01:06 AM
