I have a 2000 f-450 7.3 that is a bucket trucket. Has 16.5 gvw frame and my truck with the boom and all equiptment usually weighs aroung 13.5k
When I am in soft dirt and there is a little resistance on the wheels the truck will not back up out of dirt. The motor only revs up a little and will not pull out of dirt.
Even worse in mud except the tires will spin in mud.
I saw another 7.3 have the same problem in dirt in reverse.
Could there be a motor problem not giving it enough power or is it all the weight on truck not letting motor spin tires and get me on up out of dirt. have around 250k on motor.
Thanks for any info.
Steve Polk
I also have a 2000 f450 and had similar problems but mine would do it no matter what surface I was on. I ended getting the tranny rebuilt with billet torque converter etc. And has been great ever since. Does this only happen when you are in dirt? Mark K would probably be the best one to answer your questions as he is the transmission guy here on this forum. If you still have the original transmission that is pretty good for 250,000 miles. It might be that time.... others will be along shortly
I dirt or ether in a small hole it just wont go backwards. I take my turck off in ditches and such to reach the utility poles. Amd if it is steep bank I have to back out of forget it.
Just had transmission checked out said all is good. Had fluid filters gaskets changed for 1st time. Just needs a little moore power from motor to get me back up the hill or out of hole.
Thanks for the advice.
Trans can overheat pretty quickly in reverse. Commonly the OE front seal will get soft and burp out some fluid. At least on F250 and F350, not sure if reverse is geared so high on F450 and up.
Cure is a trans cooler from a model year with a 6.0 engine and a real transmission temp gauge. OE dash gauge only indicates hot when it is close to critical.
Of course temp might not be your issue at all. Just FYI the conventional wisdom regarding backing issues with a 4R100.
Now, after performing arcane sigils and live sacrifice, I summon 4R100 guru @Mark Kovalsky .
Yes sir, accelerator is on floor, just kinda boggs down. Rpms im not sure betwwen 1 or 2k. When accelerator is on floor the rpms inch up just a littl. You can hear it trying to raise rpm but just wont go. Just not enogh rpm to move tires, you would think motor revs up high and start spinning wheels, but not enough rpm to spin tires.
There was another similar 7.3 and he had same problem in soft dirt.
Trnsmission cooler maybe, my truck runs all day mostly parked at locations to operate boom.
Motor needs just a little more power to the wheels, wonder about a basic tuner to use ONLY in those situations, and use it for fuel mileage also??
The transmission cooler can't possibly be the problem. I think the problem is that the engine isn't making enough torque at low RPM and reverse gear is too high. I don't think there is something wrong, I think it isn't the best design to do what you need to do. A tuner may help.
I think a tuner also. saw a truck just like it having same problem. I would use the tuner only when needed. Of course id like to use it for hwy mileage also. Don't know anything about tuners but Im looking at a superchips flashpaq5 that was recommended for my truck??
