Adding Sway Bars
Old Jul 25, 2020 | 05:48 PM
95fiveoh's Avatar
95fiveoh
Adding Sway Bars
Hi all, I've made a trip to the junkyard today and bought some sway bars for my 1995 F150. The metal plate that the front sway bar mounts to is all bent, does anyone have one they would sell?
And for the rear sway bar, how do the end links attach to the frame? On the truck I removed the bars from, it had some brackets riveted to the frame for them at the red circle, but my truck doesn't have those. How should I deal with this?
Here is everything I purchased-
Old Jul 25, 2020 | 06:46 PM
Binkowski's Avatar
Binkowski
https://www.ford-trucks.com/forums/1...ssing-out.html
Old Jul 25, 2020 | 06:54 PM
95fiveoh's Avatar
95fiveoh
That's for an aftermarket Hellwig bar, it doesn't have much in common with the factory sway bar.
Old Jul 25, 2020 | 07:17 PM
torq'ta 5 8's Avatar
torq'ta 5 8
I was always under the impression, the plate was on 2wd, also, you thought about heat and whooping it? The rear end links, attach like bottom of shock, wonder if you just make one, out of C-channel
Old Jul 25, 2020 | 07:31 PM
95fiveoh's Avatar
95fiveoh
I might try to straighten that plate out but it may be easier just to replace.
Do you have any other pictures of the rear sway bar end link brackets? A piece of c-channel might be the best way to go.
Old Jul 25, 2020 | 07:46 PM
torq'ta 5 8
with lengths, need more? let me know
Old Jul 25, 2020 | 08:04 PM
95fiveoh's Avatar
95fiveoh
You rock man! Thanks! I'll let you know if I need any more!
Old Jul 25, 2020 | 08:15 PM
95fiveoh's Avatar
95fiveoh
I wonder how close the dimensions on these would be?
Old Jul 25, 2020 | 08:28 PM
95fiveoh's Avatar
95fiveoh
Also found this-
Sway Bar - Gary's Garagemahal (the Bullnose bible)
5L499, does that part number still exist?
Old Jul 25, 2020 | 08:31 PM
95fiveoh's Avatar
95fiveoh
Also this. Broncos and 2WDs bolted straight to the frame, but 4WDs had those brackets.
Old Jul 25, 2020 | 08:34 PM
torq'ta 5 8
thats like your plate, 5C128 is its #
Old Jul 25, 2020 | 08:42 PM
95fiveoh's Avatar
95fiveoh
I wonder if I should just mount it up like the broncos and 2wds did and just skip the brackets?
Old Jul 25, 2020 | 08:53 PM
torq'ta 5 8
I think they did bracket for reinforcement on 4wd, and end link supported with through bolt, instead of the bolt getting all the jolting, when 4 wheeling
Jayv10
Apr 30, 2020 09:53 PM
kramttocs
Dec 31, 2018 06:25 AM
my3sonsdad
Dec 11, 2018 10:36 PM
psquare7575
Nov 2, 2011 07:43 PM
firstrider
Dec 9, 2008 01:05 PM
