94 4.9 Issues
Old Jul 30, 2020 | 08:46 PM
f1502's Avatar
f1502
Had an '89 - 4.9 - 5sp 115k when I bought it (2000) probly 160k when it started having similar problems. Would stall when warm for awhile, on warm days the most, highway for 30 minutes etc.Let it sit for 10 - 15 minutes and would take off fine. Chased things around for a few months, dealer ran diags, found nothing.
Having tried so many things, drove it around one day until warm. parked in the driveway let it run, didn't stall.
But noticed that emissions charcoal can (that one WAS a coffee can). Unhooked the inlet and outlet lines and let them breathe for a few days, no problems.
The can was clogged - saturated?
Old Jul 31, 2020 | 05:41 PM
torq'ta 5 8's Avatar
torq'ta 5 8
member here was moving, and chasing hi idle, checked his new(not motorcraft) IAC, and it was bad
How to Clean and Test your IAC - Ford Bronco Forum
before replacing your TPS test it, you dont even have to remove it, unless its bad
Throttle Position Sensor Testing, Replacement and Adjustment - Ford Bronco Forum
mattl468
Mar 10, 2014 09:20 PM
rupejosh
Feb 18, 2011 11:28 AM
fordinmudd
May 24, 2010 03:22 PM
b0unc3r
Sep 17, 2007 01:55 PM
firemancrash_448
Dec 29, 2000 10:35 PM
