LED Upgrade
Old Jul 26, 2020 | 11:48 AM
AdirondEx's Avatar
AdirondEx
Temporarily Deactivated
Huge difference ocwill. The Beamtechs made a big difference too over halogens.
Old Jul 26, 2020 | 11:55 AM
Mattm400's Avatar
Mattm400
^^^^^^ Ditto on this^^^^^^
These are what I used.
Old Jul 26, 2020 | 11:56 AM
ocwill11's Avatar
ocwill11
Pardon me for going off-topic, it's the ADD thing, but what kind of flooring is that? Do you like? Looks good. Nice headlights, BTW.
racedeck flooring and I love it.. www.bigfloors.com has a good selection. they have racedeck, garage deck, and garage trac all compatible with each other. i just ordered garagedeck replacement for the flow through that I have around the edge of the parking spots, the flowthrough hurt my feet when barefoot...
Old Jul 26, 2020 | 12:52 PM
AMEC Electric LLC's Avatar
AMEC Electric LLC
I went with the Headlight Revolution V.4s in the headlights and driving lights. Huge improvement. The headlights do need to be adjusted"down" after install though.
Old Jul 26, 2020 | 02:10 PM
BillyE's Avatar
BillyE
I’ve had the same experience with Beamtech. If you don’t adjust them, low is hi and hi is in the trees.
Old Jul 26, 2020 | 08:21 PM
SDGator's Avatar
SDGator
Originally Posted by Jimmy Pet
Same
I put Beamtechs in my '19 about 7 days after it arrived home from the dealership, light is 100% better than the horrible stock lights and I have not been flashed once by an oncoming driver.
Pattern is as good as stock, just now I can see.
Ignore the LED swap doomsayers.
Considering I couldn't friggin' see on the long drive home from the dealership, I'm good for now. I'm surprised someone hasn't sued Ford over the stock halogen headlights. I get more light output from my '80s Foxbody Mustangs.
I also looked at the posts before buying and really compared the beam patterns at different distances before I drove it anywhere.
Old Jul 27, 2020 | 05:40 AM
Poncho450's Avatar
Poncho450
Originally Posted by mhuber
Beamtech guys, It seems like you like these so far. Any problems with them holding up in extreme cold / heat. Problems like flickering ... I normally spend a bit more but for the price I think Ill give them a shot. I just want to avoid those cheap looking leds if you know what i mean
Thanks again for the replies
I was the first from this forum to install them to the best of my knowledge and started the original thread cited earlier. That was in December 2017. I used them in that truck until I traded it in September 2019. I kept the bulbs and put them in my then new 2019. Still in use. Still no issues.
I see the usual naysayers are out with their snide comments. Whatever. Life's too short to argue with internet strangers. They should be more concerned about the idiots with 4 foot LED light bars in their grill that use them on road.
I got great results for low cash outlay and have very seldom been flashed in over 2 years. If you install them check your height adjustment. I found that mine were set as high as they would go from when the truck was brand new on my 2017 and had to adjust them downward. In the end it's your truck and your money. Spend it as you like.
Old Jul 30, 2020 | 01:53 AM
hobbie1's Avatar
hobbie1
Why yes, yes I do
Any issues with flickering? Do you have auto high beam / low beam on your truck? Any issues with that option and or your daytime running lights.
I have the GTR Ultra 2's with the PWM modules.
Started having flickering issues with driver side lower left lamp. Very intermittent. More so when I apply the brakes.
I think this was happening all along I just happened to noticed when parked in front of some glass windows where I could see the lamps in the reflection of the glass.
Talked with GTR - replace the lamp and the PWM - still doing it.
I removed them tonight and put the halogens back. Would hope there are no issues with your setup given the cost for a set.
Same questions for Beamtech users too
I hate the Halogens - they are sooooo bad.
Old Jul 30, 2020 | 07:39 AM
AdirondEx's Avatar
AdirondEx
Never noticed any flickering with Beamtech or the Morimotos. Daytime running lamps [ ] are now on an upfitter switch so they can be controlled separate. Good question on the auto high beam which I didn't care for to begin with. May have turned that off before the install.
Old Jul 30, 2020 | 05:37 PM
hobbie1's Avatar
hobbie1
Anyone gone this route?
https://automotivecustomlighting.com...ed-headlights/
https://thehidfactory.com/product/pa...ed-headlights/
Old Jul 30, 2020 | 06:27 PM
75Mike's Avatar
75Mike
I went with the Morimotos. Absolutely love them.
Old Jul 30, 2020 | 08:32 PM
'18_F250_4x4's Avatar
'18_F250_4x4
Originally Posted by 77mmbass
I just put a set of Beamtechs in the '19. Took 30 min, even removed grill for drivers side.
They look great.
Put the fogs in after. Took about 3 minutes.
I just got a full set of BeamTechs and a quick look at the location of the lights made me think this was gonna a little more work than first thought.
Fogs are easy-peasy, no issues; the passenger side seems accessible but is there a "trick" to releasing the OEM lights? Push in and rotate, rotate left/right or get a freekin hammer? And the Drivers side looks pretty cramped spaces; 30 min to me sounds pretty awesome so please give up the secrets to a :30 install they would be greatly appreciated.
(FWIW it was 104F so I did not spend too much time roasting in the sun...)
Old Jul 30, 2020 | 08:45 PM
  #28
Cam B's Avatar
Cam B
I think I might try these out when I get my truck:
https://ddmtuning.com/SaberLED-ProX-...bs-12500LMPR-W
BulbFacts ranked them at the top of high-end led bulbs.
https://bulbfacts.com/led-kits/chart/
Old Jul 30, 2020 | 08:51 PM
  #29
hobbie1's Avatar
hobbie1
I had to use a rag to protect the bulb ends and a pair of pliers - they were in really tight. Also I've did the access both ways through the top removing the air tube and removing the grill. In my opinion the grill route is easier.
Here are a couple of videos.
Old Jul 30, 2020 | 09:17 PM
  #30
Cam B's Avatar
Cam B
I keep seeing videos of guys pulling out their entire headlight assemblies to change their bulbs, until I seen this guy's video:
I know removing your grill and headlights isn't a huge deal, but it seems like this method is lot simpler.
