Sponsored by: Real Truck
Power window issue
Old Jul 23, 2020 | 05:55 PM
Paulst's Avatar
Paulst
Power window issue
Hello, wondering if I can get some help. Have a 2000 f350. Did some upgrades turned out well. However, all of a sudden my power windows don’t work on any switch. No registered power to the main switch driver side. Checked all fuses and relays. All good. Weird part is, I get weak power going to the auto power window relay. When I do press and hold one of the power window switches down the speedometer moves to about 10 mph. Reminder the trucks not moving. Very weird, scratching my head on this one.
Old Jul 23, 2020 | 06:47 PM
Djosbun's Avatar
Djosbun
Sounds to me like either a voltage drop issue or a ground problem. With everything off, including the truck, do the power locks function? If yes, you will need to do some diag to find the voltage drop. If locks do not work with the truck (and all accessories) off, check all of your grounds. Should be clean and green-free.
-- Dave
Old Jul 23, 2020 | 08:36 PM
Paulst's Avatar
Paulst
Thanks for the response. The power locks work, it is the windows. Might be the same fix though.
I’ll give it a go
Paulst
1997 - 2003 F150
Aug 1, 2020 09:16 PM
bulletproof6.0
Nov 14, 2013 01:44 PM
djyngs
Apr 13, 2002 07:53 PM
yezek6
Aerostar
Apr 12, 2002 01:03 AM
