rear gear selection
Old Jul 23, 2020 | 07:23 AM
chiefdave's Avatar
chiefdave
rear gear selection
The 223 I6 in my '62 F100 winds a bit tighter than I would like at highway speed. The VIN tag and toe tag on the diff both show a 3.70 ratio. I'm thinking about a 3.25 or 3.00:1 ratio and would like to draw from the experience of other forum members. The engine is stock except for headers, a 38/38 Weber carb on a Clifford manifold and a later model distributor. The truck is a daily driver and will likely never see north of 70 MPH.
Old Jul 23, 2020 | 09:27 AM
CJ McGee's Avatar
CJ McGee
I had a different motor, but I swapped my rear gears from 3.89 down numerically to a 3.25 and I’ve been very happy with it. I don’t have a tachometer so I’m not sure how fast it’s spinning. I typically run around 67mph on the highway and my 292 y block seems pretty happy at that range.
Old Jul 23, 2020 | 07:09 PM
Vandy23's Avatar
Vandy23
Went from 4:10s to 3:54s, truck drives like a dream!
Old Jul 23, 2020 | 07:25 PM
john jamieson's Avatar
john jamieson
My '66 with a 240 had 3.50:1. I swapped in a 3.0:1 after some teeth broke on the pinion gear. I like the 3.0 but starting on any good slope is an effort for the old engine. I'm thinking that the 300
I'm going to put in will work well with the 3.0 gears. Unless you already have the gears, I think 3.25 would be the make you would want with the 223.
Old Jul 26, 2020 | 07:39 AM
cosmofennema's Avatar
cosmofennema
My '66 with a 240/3 speed also had/has a 3:50. Probably the perfect gear for the use, as I can get up hills (I live in Wisconsin), and still cruise at 85 if need be. As has been stated, going much taller will overly stress takeoff, leading to early replacement of the clutch.
Old Aug 1, 2020 | 07:54 AM
chiefdave's Avatar
chiefdave
Thanks to everyone for sharing your personal experience. Using Spicer's rpm vs mph calculator I came up with 2639 rpm @ 65 mph using 3.25 gears which is livable. Having one built using all new parts.
Old Aug 3, 2020 | 08:13 AM
jowilker's Avatar
jowilker
Mr Dave, when your truck was designed, it was only meant to go about 45 mph, they were mostly driven on dirt roads and trails so higher ratios were installed. A lot has changed in the nearly 60 years since it was built. I wouldn't recommend going below 3.25 because you will kill the pulling power. my 2
John
Old Aug 3, 2020 | 10:37 AM
Pickupmanx2's Avatar
Pickupmanx2
I'll throw in my .02 fwiw... my 66 F100/240/T18 had 3.00's in it when I got it (I didn't know the ratio), was just a bit of a dog up here in the mtns, the flats were..ok..thought the 240 was just tired, came across a 302, figured I throw in while I rebuilt the 240, in the meantime, rear end started making noise, pulled it, found out they were 3.00's, swapped with a guy for a 3.70 9", Holy cow!! Huge difference, brought Shrek alive, I then changed to 15x8 rims with 265/70/15's, speedo is spot on and I get 18mpg running to fresburg and back now.
All this just to say, don't go too high a ratio, you'll be out of the intended rpm range and you won't like it, buy a Tach also.
Old Aug 5, 2020 | 07:03 PM
'62 Susie Q's Avatar
'62 Susie Q
Dave, who do you have doing the work? I have a leaking pinion seal and I'm having a heck of a time finding a shop to do the work (I'm considering gears and wheel bearings while its apart). The most recommended shop here in Norfolk is closed due to our friend COVID-19.
Old Aug 5, 2020 | 10:36 PM
chiefdave's Avatar
chiefdave
Quick Performance in Ames, Iowa. I went with an all new unit but they do offer refurbished units. And they do offer a military discount. How is Suzie Q progressing?
Old Aug 6, 2020 | 04:12 PM
dubya TF's Avatar
dubya TF
Check out Speedway for their 9" 3rd members too.
Old Aug 6, 2020 | 07:49 PM
chiefdave's Avatar
chiefdave
John
Thanks for your input. 3.25 was my final choice. The tires now on the truck are 9/10th" shorter than the originals so that will have an effect on the overall gearing. This is just a fun truck and will never be asked to haul or pull a load. I did add headers and an intake system which Clifford claims would increase power 70% or 95 HP. To me that sounds overly optimistic and I expect the gain might be 40 HP which will help me get down the road comfortably..
Old Aug 9, 2020 | 11:48 AM
'62 Susie Q
Dave, sorry I'm a little slow getting to your question. Just finished the complete brake job. Even with the original design (single master cylinder, drum brakes, etc), it really makes a difference. As I mentioned earlier, I think the rear diff is next as it's leaking at the pinion and I'm nervous about the rear wheel bearings. No real hurry to tear her apart completely until I get settled next summer.
Old Aug 22, 2020 | 07:27 AM
chiefdave's Avatar
chiefdave
I'd like to thank everyone for their input. The 3.25's are in and worked out quite well. RPM dropped to the comfortable level and the engine has no problem pulling the hills here in the Ozarks in high gear.
Old Aug 23, 2020 | 04:51 AM
624WD's Avatar
624WD
This was a helpful thread. It helped me determine the direction I need to best purchase wheels and tire sizes for my gear ratio and transmission.
