2020 reverse wire?
Old Jul 22, 2020 | 08:46 PM
2017-350's Avatar
2017-350
2020 reverse wire?
Does anyone know the color of the reverse wire on a 2020 with BLIS? I want to tap in some auxiliary lights but didn’t think there would be so many wires in the harness. I don’t really want to poke everyone with a tester so I thought I would try here first. Thanks.
Old Jul 23, 2020 | 06:16 AM
1olddogtwo's Avatar
1olddogtwo
Going off the tail light harness may cause the BCM to cut power to the circuit. Best bet is use the tow circuit. Center wire on the 7pin.
Old Jul 23, 2020 | 07:29 AM
2017-350's Avatar
2017-350
I had it to my reverse wire on my 2019, but it didn’t have BLIS so it was easier to find...but it never tripped the BCM. On the center wore of the tow harness, doesn’t a trailer have to be hooked up for that to work completely?
Old Jul 23, 2020 | 07:41 AM
Rich53's Avatar
Rich53
No, the only lead that requires the trailer to be hooked up is the 12 volt charging lead, as far as I know the taillight circuits are always live.
Old Jul 23, 2020 | 07:59 AM
2017-350's Avatar
2017-350
So is the center pin always hot or is the center pin the reverse light?
Old Jul 23, 2020 | 08:19 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
So could you just plug/play extra brake lights to that harness like as if it was trailer brakes ?
Is this where they plug in for e tra brake lights that zre added above the rear window ?
Old Jul 23, 2020 | 09:10 AM
2017-350's Avatar
2017-350
I ended up doing a little more searching and found that it was the green with brown trace wire....it’s the same on earlier model trucks. I got lucky.
grec-o-face
Dec 28, 2013 09:49 AM
SGTSIXER
1997 - 2003 F150
Sep 29, 2012 03:23 PM
kingkong1
Dec 12, 2010 07:15 AM
pminne
Feb 25, 2010 07:53 AM
bohiaa
Dec 17, 2008 08:01 AM
