Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1966 F600 VIN decoding help
Old Jul 22, 2020 | 06:55 PM
augustmaine's Avatar
augustmaine
Hi all, would you help decoding this VIN. Looking at the truck this weekend and thinking of buying. Any way to estimate its value. Frame seems fairly clean with little rust or rot. Engine may be stuck. Thanks.
Old Jul 22, 2020 | 07:24 PM
85e150's Avatar
85e150
I can give you a couple items.
Engine code C: 330 2v medium duty FT engine.
GVWR 17000 lbs, you knew that.
Wheels: You have the "Dayton" or "Western" style of spoked wheel. Congrats, you dodged the widowmakers! If those are tube-type tires, you can either stick with those or convert to tubeless by getting the 22.5" tubeless rims that will bolt right up to your spokes.
All that equipment on there, is that something you want?
When you look, step on the brake. Should be hard as a rock with the engine off.
Check the insides of the tires. Black, "clean looking" stains may indicate a blown wheel cylinder with brake fluid leaking. Fixable.
Brake drums are not to be had. They are usually ok. There have not been a lot of posts here on these trucks with bad drums.
Old Jul 23, 2020 | 04:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F60 = F600 (gas).
C = 330 2V Medium Duty FT engine.
E = Mahwah NJ Assembly Plant.
820481 = 1966.
174" Wheelbase.
J = Rangoon Red.
F600 (gas), 17000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl // 81 = 81A Standard Cab.
L = Clark model 2651-V1 or 2653-V1 5 Speed Direct Manual Transmission.
F8C:
F8 = Eaton model 13802 Two Speed Rear Axle // 6.33/8.81 // 15,000 lbs. Rear Axle Capacity.
C = Ford-Rockwell/Timken 6,000 lbs. Capacity Front Axle.
17,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
11 = Boston MA Ford District Sales Office, where the original selling dealer ordered the truck from.
Rusty Fords
Jul 16, 2020 06:34 PM
Rusty Fords
Apr 27, 2020 10:47 PM
Drew Lear
Large Truck
Feb 27, 2020 10:39 PM
crawlspeed
Large Truck
Jan 1, 2020 09:38 PM
JakeK
Mar 4, 2018 05:59 PM
