Emissions question - manifold studs
Old Jul 21, 2020 | 06:16 PM
phix's Avatar
phix
So, I have an 03 expedition, 198k, 4.6l. Check engine light on, too lean on passenger side: broken manifold studs. I know the right thing is to take manifold off and replace the studs. I have neither the time or space to do that right now, also not sure about giving my local Indy $1200+\- to do it, and jury is out about keeping the expedition going a lot longer. With all that in mind is there a trick or hack to fool the sensor into not sensing too lean, get the light off, pass emissions? Thoughts, opinions, suggestions are definitely welcome. Thanks
Old Jul 21, 2020 | 08:18 PM
meborder's Avatar
meborder
$1200 is steep.
i paid less than $700 to do the passenger side on my 2014. Local independent shop prices at $90/hr shop time.
I’d check around.
you can probably fool the oxygen sensor with a spark plug non-fouler, but it won’t pass emissions if they see it in there during a visual.
Old Jul 22, 2020 | 12:26 PM
phix's Avatar
phix
Thank you for your input. I might do some shopping around yet before I make a final decision.
Old Jul 22, 2020 | 01:16 PM
lv2race's Avatar
lv2race
Call around to exhaust/muffler shops.
Old Jul 22, 2020 | 02:44 PM
projectSHO89's Avatar
projectSHO89
Nope. The anti-fouler suggestion previously provided is misapplied. It isn't for use with the upstream sensors.
Exhaust leaks upstream of the upstream sensors can indeed cause "lean" codes if fresh air hits the sensors. Usually, vacuum leaks account for over 90% of the occurrences of those codes so you might want to rule that out first.
Old Jul 23, 2020 | 07:09 PM
phix's Avatar
phix
I was wondering about that. When the CEL originally came on it was reading a bad MAF sensor. I replaced that, and CEL still on, I had checked over vacuum and didn’t see anything cracked or loose, still CEL I’m, hence I ended up at the shop.
Yesterday, for kicks, since nothing else seemed to be working and I was going to be on the road all day with it, I cleared the stored codes, and patiently pounded on miles waiting for the CEL to come back on. 320 miles later, and no light. So tonight on my way home from work I had emissions test done and we are in the green. So, I still have broken studs and will need to navigate that, but I made my emissions test deadline so at least I won’t get a ticket. Thanks for always having ideas, thoughts, and input. Keep Fording on!
hivoltj
2004 - 2008 F150
Jun 25, 2019 03:53 PM
teamlx88
Oct 11, 2011 07:40 AM
saberworks
16
Oct 29, 2010 11:34 AM
skyjacked4x4
1997 - 2003 F150
Oct 17, 2005 11:23 PM
hink10
13
Jul 4, 2004 01:52 AM
