I wish i had the specific manual for the A/C here . It is in the trailer which i wont get to for another 2 weeks. The Keystone manual reads the roof top A/C as between 13 -15 amps. So that would be between 1560 to 1800 Watts running i think.
Dont worry about amps. What size is it? 13.5k BTU or 15k? Then use chart above.
I can tell you the Predator will run 15k BTU unit as I have done it with no issues.
Make sure to break it in before camping. Run 1 hour then change oil. Ideally you want to then run it up to 25 hours with a light load and change oil again.
I don`t know what size it is , The trailer is up in camp 100 miles or so away . I will be up there on the 13th to pick it up ( we use it as a spare bed room there ) Things have changed so i remember when a 15k unit would have required 240V or is that wrong ? Went to school in 1977-78 to be an HVAC Tec .
So this being the first generator i`ve ever own . What does a power management system do ? if i plug the 30 amp service cord from the trailer in to the generator are you saying that i need another device between them ? Here is the manual for the Generator https://manuals.harborfreight.com/ma...3999/63584.pdf
Some people do. These generators don’t have a bonded neutral so the PMS won’t allow power to flow to camper. If you have a simple surge protector you should be fine.
Just ordered the bonding plug you mentioned . with shipping these days just hope it gets here in time. Interesting video watched it before on the Forest River site while researching generators but didn`t understand why i needed it . Not as smart as i used to be 😀
BroncoRn, Thanks for the video above! I normally don't use my Progressive EMS 50 when using my Honda 2200's, not sure if I would need the "bonding plugs" but I ordered one for each of my 2200 just in case.
Never hurts right? Camper fridge, inverter, ac units, hot water heater, are all expensive!
Generators and RVs are sometimes left un-bonded with the expectation that bonding is done somewhere else within the system (code only allows once). If it’s not, you really need a bonding plug, EMS 50 or not. It’s a safety thing.
