Washers on head bolts
Old Jul 20, 2020 | 05:52 PM
TGM's Avatar
TGM
I’m using 5/8” bolt head , not 11/16” , head bolts on my 239ci 8BA . Just wondering if I should be using flat washers because of the smaller bolt head size. Any thoughts ?
Tim
Old Jul 20, 2020 | 06:01 PM
Mixer man's Avatar
Mixer man
Tim
Good question. What is the grade of your 5/8" headed head bolts? Any washers for that purpose should be grade 8 and SAE sized, not a sloppy nominally sized washer.
Old Jul 20, 2020 | 06:45 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Just curious.....how is this possible? if it was originally an 11/16 bolt how are you managing to get a 5/8 to thread in and hold?
But, i see no reason why you couldn't or shouldn't have a washer on there providing it was like Bob mentioned and was the right sized washer for the bolt.
Bobby
Old Jul 20, 2020 | 07:13 PM
Mixer man's Avatar
Mixer man
Bobby
7/16" bolts (all grades) have a 5/8" hex head. The "heavy hex" (oversize hex) come in some larger sizes 1/2" and up. 7/16" nuts are also 5/8" for all grades, with the exception of "heavy hex" nuts which are 11/16" hex. The 11/16" hex 7/16" head bolts are a special grade, approximately between grades 6 and 7.
I might add that machine threaded bolts are better than roll-threaded bolts.
Old Jul 20, 2020 | 07:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Another problem will be that the blocks and the OEM head bolts are a tighter-than-standard thread class, to prevent leakage. Hardware store bolts will not have as deep of thread engagement.
As far as washers, you'll probably need them to prevent water leaks. Grade 5 should be fine but should be SAE washers as noted. Rolled threads are fine.
Old Jul 20, 2020 | 09:04 PM
TGM's Avatar
TGM
VanPelts offer a 7/16 “ head bolt with either a 5/8 “ hex head or 11/16” hex head . My thought was it may be better to have a washer with the smaller 5/8” head . Maybe I’m just over thinking things .
Im using grade 8 bolts
thanks for all your input , I appreciate it .
Tim
Old Jul 20, 2020 | 11:04 PM
Mixer man's Avatar
Mixer man
Ford recommends using a thread sealant on headbolts. I use and recommend RectorSeal #5.
Old Jul 20, 2020 | 11:08 PM
bobbytnm's Avatar
bobbytnm
Cool
thanks for the lesson. I learned new stuff! woohooo
Old Jul 21, 2020 | 03:19 PM
TGM's Avatar
TGM
Thanks Mixer man appreciate your help.
Tim
Old Jul 22, 2020 | 09:23 AM
AZAV8's Avatar
AZAV8
If you use washers make sure you use a thread lube on both sides of the washer. You'll need to do this in order to get a good torque reading. Also rolled threads will give you a better torque reading than machined threads. The thread surface is smoother on a rolled thread than a machined thread thus giving a more accurate torque reading. I learned all of this being an engineer in the nuclear energy business where accurate torque readings are essential. I second Mixer Man's recommendation on the thread sealant to prevent leaks. It will also lube the threads when torquing, i.e. until it hardens.
Old Jul 22, 2020 | 11:15 AM
Mixer man's Avatar
Mixer man
That's one of the nice things about RectorSeal #5, it doesn't harden.
Brief read about rolled vs. machined threads.
https://www.globalfastenernews.com/w..._Threading.pdf
Old Jul 22, 2020 | 02:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Tim, if you still have the original head bolts, compare their lengths to the new ones. The decks on flat V8's are notoriously thin, so you want the same amount of thread in the block. Washers might reduce that too much.
I'd also torque to 55 ft-lbs, not the manual's 65-70.
Are the bolts with 5/8" heads for aluminum heads?
Old Jul 22, 2020 | 02:56 PM
AZAV8's Avatar
AZAV8
The Nuclear power industry used the Electric Power Research Institute to do research on the technical needs and to produce uniformity in practices and procedures in the industry. My knowledge about bolted joints comes from their research papers. That research showed that to get uniformity in the torque application to the bolted joint, that rolled threads produced the the most consistent results. Or that is what my over 40 year old engineer memory tells me.
Old Jul 22, 2020 | 04:32 PM
Mixer man's Avatar
Mixer man
My engineering memory is older than yours, and undoubtedly more faded , but then again this isn't about nukes or rocket science, it's about a 60-odd year old Ford engine. But I can tell you this fwiw, - a 90,000 HP Sulzer 12RTA96 diesel engine has no rolled threads in it anywhere.
Old Jul 22, 2020 | 10:40 PM
AZAV8's Avatar
AZAV8
That is what I love about engineering, everybody's experience is different and those differences still produce excellent results. If your engineering memory is older than 73, then you are older than me and great for you.
I only refer to nuclear power because that is my experience and it can be applied to other things. We all still want to make the 70 year old flathead run without leaks, You makes your choices based on what you think will make the old girl run.
One thing I have learned from this forum, is that it will give you a fountain of good information all intended to help you out in some way.
Thanks for your well considered and kindly information and opinion.
