Will leaf springs from a '73-'79 work on a '67? Someone inexpertly lowered the rear of my '67 f100 by removing all but a couple of leafs in the rear springs. It rides like a conestoga wagon and wheelhops terribly if the tires spin. I have access to springs from a '75 and a '75 1/2 ton.
1957/67 F100 rear springs interchange, as do 1968/72 F100 without Flex-O-Matic rear suspension. Springs are 2 1/4" wide, 24" > eyebolt < 28."
1973: Ford increased the width between the inner frame rails behind the cab from 33 1/2" used 1961/72 to 37 1/2." These rear springs are 2 1/2" wide, 26" > eyebolt < 26."
What I do sometimes is check rock auto for the two different trucks and then compare part nuimbers. Did it on springs I had for a 95' and found they were same as the 88'; which they are now on !
