1971 ford pickup
Old Oct 19, 2003 | 05:55 PM
elphany's Avatar
elphany
1971 ford pickup
we ar trying to figure out how to install a wiring harness for under the dash
Old Oct 19, 2003 | 08:16 PM
Sberry27's Avatar
Sberry27
Thats a pretty limited statement. Whats the problem? I dont personally have a lot of experience with ones that old, a lot with 73 thru 78 and they are modular in nature, string the new one out under the dash, the 73 series only plug in one way. Each plug only fits one connection.
Old Oct 19, 2003 | 09:08 PM
elphany's Avatar
elphany
plugged in new ignition switch wire shorted out and burned up switch and plug in. need locations for wires to plug into new ignition switch.
Old Oct 19, 2003 | 09:36 PM
Sberry27's Avatar
Sberry27
I am sure somehere there is a drawing to the switch, but there cant be many poles on it, you need an ohm meter and locate each function on it, should take a couple mins, a test light to locate the terminals on the plug too. The switch probably has only about 4 or so wires, power, start, run and accy
Old Oct 20, 2003 | 12:18 AM
Torque1st's Avatar
Torque1st
Posting Legend
Sberry27- Please do not answer truck tech questions that are posted in the Garage Forum, ignore them or report them to a moderator.
elphany-
Welcome to Ford Truck Enthusiasts! The Internet's leading Ford TRUCK and SUV Resource!
This thread has been moved from Garage and Workshop Tips forum where we share ideas about how to organize tools, heat the shop, or free that rusty bolt.
Unfortunately no truck tech questions are allowed there. Please scan down the list of available forums and place your topic in the most specific forum you can find, -fairly simple to do and just takes a moment.
Please take the time to read the headings and notices in each forum. The FTE board is HUGE! We want users to be able to find answers to their questions so it is organized into many areas and search tools are provided.
If you have any questions please feel free to contact a moderator.
Please turn on your email function. Users do not have access to your actual email address.
Thanks for using FTE!
