Starting System Fault
Old Jul 18, 2020 | 12:39 PM
John8061's Avatar
John8061
Hello Everyone,
2016 F350 6.7, 22,300 miles. Stopped for fuel, pickup would not restart. ONE time received message "Starting System Fault". Removed battery cables for about 10 minutes, used both keys provided from dealer, do not have remote start. Removed #18 fuse from board. None of these produced any change, truck will sputter a few times but not start.
Any help you could provide would be appreciated.
Thank you, John
Old Jul 18, 2020 | 12:58 PM
senix's Avatar
senix
check the fuel pump relay. Used or at least still is on my 2013 on the dash. Passenger side when you open the door. See if the relay has been tripped.
Old Jul 18, 2020 | 02:07 PM
John8061's Avatar
John8061
Hello Senix. Thank you for the reply. It seems I can push the relay. How would I tell if it has tripped? Pushing did not resolve any the issue.
Old Jul 18, 2020 | 03:15 PM
senix's Avatar
senix
If it was tripped you would nave had to push it in.
Old Jul 18, 2020 | 03:17 PM
Desert Don's Avatar
Desert Don
Does the starter crank the engine? Or not? 2016 on original batteries might be a stretch for the batteries.
Old Jul 21, 2020 | 09:28 AM
John8061's Avatar
John8061
Hello 99150,
Thank you for the reply. Initially, I was skeptical of your suggestion. Regardless, towed by Ford Roadside to dealership who confirmed battery failure. All issues resolved by battery replacement.
Thank you again, John
Old Jul 21, 2020 | 10:34 AM
John8061's Avatar
John8061
Also, wanted to add, with all the technology in these vehicles it is amazing there is not a notification for low battery voltage...
road_greaser
Jun 24, 2020 02:08 PM
Heathmc
Mar 16, 2020 01:53 PM
Tonyplane
6.2L V8
Jul 2, 2014 07:26 AM
blzfan1963
1997 - 2003 F150
May 13, 2007 09:51 PM
Torque1st
1983 - 2012 Ranger & B-Series
Jan 4, 2003 12:57 AM
