TPMS Fault
Old Jul 18, 2020 | 07:22 AM
Chris3's Avatar
Chris3
TPMS Fault
I have the left front TPMS not operating... the tires were rotated over one year ago... all was fine until today. What do those lines mean for the left front.... bad TPMS? see pic
Old Jul 18, 2020 | 08:13 AM
Motor Head's Avatar
Motor Head
Try training all TPMS sensors, and see if you still have the problem after some miles. If it does act up again, more than likely you do have a faulty sensor.
Old Jul 19, 2020 | 11:47 AM
Chris3's Avatar
Chris3
Okay thanks... will try that
Old Jul 19, 2020 | 11:54 AM
seville009's Avatar
seville009
A tire shop should be able to do a quick check of the bad sensor to see if the battery in it is dead.
Old Jul 19, 2020 | 05:37 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
^^^^^^^^ What they said ^^^^^^^ TPMS sensors aren't too expensive if it is bad . They are easy to retrain if still good . Hope it gets resolved !!
Old Jul 19, 2020 | 08:08 PM
Chris3's Avatar
Chris3
Are TPMS covered under basic warranty? I'm not at 3 years yet and only 21,000 km... also on original tires.
Old Jul 19, 2020 | 08:16 PM
tomoran's Avatar
tomoran
Yes, I had one replaced last week under warranty.
Old Jul 20, 2020 | 08:53 AM
Nastyman's Avatar
Nastyman
Yes, they are covered under warranty. I've so far had three of my original four replaced at less than 18,000 miles (2017 6.2L purchased Oct 2017). All three failed at different times. Tried to get the last one replaced as I assumed installation errors or material defects, but the dealer would not do it.
Old Jul 20, 2020 | 03:20 PM
Chris3's Avatar
Chris3
Re-learn didn't work... off to the dealer.
Thanks all
Old Jul 20, 2020 | 09:30 PM
stephen.osborne1's Avatar
stephen.osborne1
I had one working intermittently. Turned out it was broken inside the tire. Tech couldn't believe it worked at all. Covered under warranty.
dusty78
1978 - 1996 Big Bronco
Apr 17, 2020 11:09 PM
jake19xx
Apr 9, 2020 01:12 PM
Ptjsk
18
Feb 14, 2019 12:12 AM
Keith Mann
Jun 5, 2018 08:08 AM
hucka1a
48
Apr 23, 2011 09:34 AM
