No, I did a video about using 8020 aluminum shapes as an engine lift plate with testing after seeing the $210 lift plate that was sold on eBay. I just never finished or shared what I did for $32 as I wasn't sure everyone else would assemble it as I did. Then I made a steel plate which was more conventional I was going to sell on eBay for like $75 but never did that either......
Knuckleheaded video fer sure from the same knuckleheads who "forgot" to include a return in their earlier sumps.
Who said they forgot? I'm considering their micro sump, which doesn't have a return, and that's fine with me. The stock configuration has a useable return as do all other trucks that were designed with one. Not sure why that's an issue. For my money, I'd rather not have another hose coming from the bottom of the tank that's vulnerable.
Originally Posted by F350 1990
BTW -- there is a >50% chance the sump's oring will shift out of its recess relocation after hitting chit.
Scientifically proven data no doubt.
I watched an installation video of their newest sump (one with a return for the grouches out there) that was done by Thoroughbred Diesel, and it clearly shows a step on the top of the sump body that fits up into the hole that's drilled with the holesaw, which theoretically should keep it from shifting laterally in the event of a wack on a rock.
