Convert carbureted or MAF
Old Jul 18, 2020 | 12:02 AM
hutchens2002's Avatar
hutchens2002
I have a 92 f150 5.0l automatic trans read wheel drive all stock
so my goal with this truck is to make a show/ race truck, pretty much get as much horsepower and torque out of the motor. But with speed density idk if I could get the most out of the motor. So would a carburetor conversion or a MAF conversation be best?
any help would be awesome
Old Jul 18, 2020 | 08:01 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What automatic transmission? An E4OD or 4R70W will need input from engine sensors and the pcm or a stand alone controller to shift.
Personally I would never go backwards to a carburetor but that is your decision to make.
Old Jul 18, 2020 | 08:54 AM
Conanski's Avatar
Conanski
Don't convert to MAF
Buy a Pimpx PCM and throw whatever mods you want at it.
Old Jul 18, 2020 | 11:11 AM
Mudsport96's Avatar
Mudsport96
By the time you spend the money on either conversion you could have bought an aftermarket system.
Ad conanski said get a pimpx system
Old Jul 20, 2020 | 12:28 AM
hutchens2002
i believe it’s a E40D
Old Jul 20, 2020 | 12:30 AM
hutchens2002
I’ve never Hurd of a Pimpx pcm what dose it do and do you have a link or know where I could buy it?
Old Jul 20, 2020 | 06:50 AM
rla2005's Avatar
rla2005
Stinger Performance Engineering
The owner is a member here. I believe it's @SPE-
Old Jul 20, 2020 | 08:34 PM
Blurry94's Avatar
Blurry94
There are many bolt-ons that can be done with speed density, without aftermarket tuning; headers, exhaust, roller rockers, intake, torque converter, & a valve body upgrade....and even a 4.10 gear swap if so desired. In some cases, you could also throw in a speed density friendly cam as well and an adjustable fuel pressure regulator, but that'll be the extent. From there, you will need to upgrade the fuel system and aftermarket injectors.
Highriser4
Apr 19, 2012 10:47 PM
MustangMabry
Aug 8, 2009 12:46 PM
turboguy
Sep 6, 2005 09:38 AM
gunman_sr5
Jul 6, 2005 12:21 AM
Leprakrotch
Feb 27, 2005 11:35 AM
