1978 - 1996 Big Bronco
Bronco issues
Old Jul 17, 2020 | 10:40 AM
JV Bronco's Avatar
JV Bronco
Bronco issues
I have 2 Broncos, 1991 with a 302 and a E40D transmission automatic. The other is a 1990, 351w that was converted into a carbureted and a has a C6 transmission.
My question is can I take the E40D trans and hook it up to the 351w with no problem?
Old Jul 17, 2020 | 12:38 PM
bluovl's Avatar
bluovl
The 351w C6 has the small block bolt pattern, so I don't see why the E4OD wouldn't bolt up to the 351W. Both engines have the same small block bolt pattern.
Old Jul 17, 2020 | 12:46 PM
JV Bronco's Avatar
JV Bronco
Thank you for the info it is greatly appreciated
Old Jul 17, 2020 | 11:12 PM
Festus2's Avatar
Festus2
I'm not sure what you are swapping where, but the E4OD is computer controlled and you must have a compatible PCM or an aftermarket controller.
Old Jul 18, 2020 | 10:02 AM
Black Ford XLT's Avatar
Black Ford XLT
Correct, even if it bolts up , must have a controller -PCM ETC !!!!
88bronco87
May 22, 2019 02:05 PM
fordeverpower
Jul 28, 2009 12:33 AM
rsalter66
Engine Swaps
Apr 30, 2007 03:09 PM
broncomadness
Mar 21, 2004 10:10 PM
jmccary
Nov 11, 2000 08:57 PM
