Aerostar Ford Aerostar
Clunking issue
Old Jul 17, 2020 | 02:57 AM
TheSmallPPClub's Avatar
TheSmallPPClub
Clunking issue
My 97 Aerostar e4wd clunks whenever I shift into drive or reverse, it'll also shift a little hard sometimes . Is it possible that the transfer case could be wore out? It's obviously been serviced before as it has rtv just caked onto the mating surfaces.
Old Jul 17, 2020 | 05:39 AM
seville009's Avatar
seville009
If it were me, first thing I would check is the transmission fluid
Old Jul 17, 2020 | 11:34 AM
TheSmallPPClub
The fluid isn't fresh, it isn't completely used up but it's not bright.
Old Jul 17, 2020 | 12:12 PM
xlt4wd90's Avatar
xlt4wd90
When you say "used up", do you mean it's low?
You should definitely drain and refill with proper fluid before proceeding. Follow the procedure here:
https://www.ford-trucks.com/forums/7...procedure.html
Old Jul 17, 2020 | 01:55 PM
TheSmallPPClub
No its not low, the fluid is turning more dark than how fresh mercon would look like. Thanks for providing the procedure, a flush and a new filter will definitely be needed for this one.
Thunderhorn
1978 - 1996 Big Bronco
Jun 24, 2014 10:36 PM
Shadow351
1997 - 2003 F150
Aug 26, 2008 01:18 PM
cwt7691
Sep 19, 2007 06:20 AM
Carbak
Jan 19, 2006 04:38 PM
CLHAY
Oct 29, 2004 06:49 PM
