3 steps back
Old Jul 15, 2020 | 07:54 PM
okie trucker's Avatar
okie trucker
3 steps back
1963 F-100, 292 c.i. Y block. Just had the cable from my starter to the relay/solenoid melt itself off of the solenoid. New solenoid seems to be week. Not enough amps (or something). Engine doesn't have much power, and has a hesitation when I hit the gas pedal, that wasn't there before. One school says there is a problem with my ignition switch. I'm no trouble shooter, What do you guys say ?
Old Jul 16, 2020 | 07:42 AM
jjriley97's Avatar
jjriley97
Are you having problems with it starting or running? Your first sentence suggests starting, but mentioning the gas pedal suggests an issue with running. Did you replace the melted cable or did you just reconnect?
Old Jul 16, 2020 | 08:52 AM
okie trucker
The cable melted where it bolts on to the solenoid, and actually came apart from the solenoid. I replaced the solenoid, but now it seems the engine is not getting all the amps or volts it needs to run proper. Seeking ideas or experience to solve reason for melting and the reason for lack of engine power. One school says it could be my ignition switch, another says my starter. Do you have any input ?
Old Jul 16, 2020 | 08:58 AM
jjriley97's Avatar
jjriley97
Cable that has been compromised, ie melted, should be replaced. Think of cable like a water hose. The hose has to be in good shape for the water to flow and electrical cable is no different. I would start there.
Old Jul 16, 2020 | 01:03 PM
okie trucker
I pulled the starter cable and the positive battery cable. Both had worn connectors on them. Getting new ones tomorrow. Thanks for your help
Old Jul 16, 2020 | 04:35 PM
john jamieson's Avatar
john jamieson
Also check/clean your grounds and grounding cable
Old Jul 16, 2020 | 05:24 PM
robertrpeak's Avatar
robertrpeak
Make sure to check the other wires coming off the solenoid, they could be damaged also, possibly under the dash...
jxnslotcar
23
Aug 18, 2020 02:53 PM
JuanAndonly
1983 - 2012 Ranger & B-Series
Mar 2, 2016 04:12 PM
Frosty67
Jan 22, 2015 11:12 PM
TGCRVT
22
Sep 17, 2010 09:03 PM
xminust
Apr 9, 2004 03:48 PM
