Sponsored by: Real Truck
Transmission
Old Jul 15, 2020 | 01:30 PM
daddy4barrel's Avatar
daddy4barrel
Transmission
2000 E450 with a V10. any transmission issues?
Old Jul 15, 2020 | 03:42 PM
crewzer's Avatar
crewzer
Lightbulb
Your transmission is the Ford 4R100.
I had the light-duty version in our 2000 F250 5.4. The AT performed flawlessly for the 17 years and 140K miles we owned the truck.
I did treat and maintain the AT well, IMHO. For example, I locked out fourth gear (OD) under certain conditions (i.e., climbing grades, slow traffic) to allow the torque converter to lock in third gear and also keep the transmission from hunting between third and fourth gears.
I also installed an ATF temp gauge, a variable-speed cooling fan on the external oil-to-air cooler, and an external filter in the ATF cooler return line.
I changed all the ATF (including draining the torque converter and the coolers), the internal ATF filter, and the external ATF filter every ~50K miles. I used the 4x4 internal filter, which has a longer pickup tube.
The variant in your E450 motorhome is likely the heavier-duty version used in the pickup truck equipped with the V10 or diesel.
HTH, and best of luck!
Jim / crewzer
Old Jul 15, 2020 | 10:01 PM
daddy4barrel
Thank You for the input.
daddy4barrel
Jul 15, 2020 03:24 PM
Jayv10
Apr 24, 2020 03:45 PM
SliteLeeSykotic
Mar 10, 2016 11:42 AM
cumminsX
Dec 13, 2008 06:56 PM
ranger7998
Apr 16, 2007 12:47 AM
