Sponsored by: Auxito
ECM issues with custom build
Old Jul 14, 2020 | 02:17 PM
MSgtling's Avatar
MSgtling
Morning all,
I have a 1953 F100 that I have installed a 1999 Lincoln navigator 5.4 in. The Lincoln came with the 4r100 transmission. This transmission was scrapped as it was a 4X4 and a 4R70W installed in its place.
I have had the ECM chipped to remove emissions and PATS and we have a running truck. However, the transmission won't shift out of 1st. I am told that is because the ECM will not EVER run the 4R70W since it is for a 5.4 with the 4r100.
I am looking for any help in locating a correct ECM for a 1999 5.4 with a 4R70W combo. Looks like expeditions,VANs, and F-series may have came with the combo, but how can I be sure I have the correct ECM? Can anyone help?
Old Jul 14, 2020 | 11:22 PM
Bluegrass 7's Avatar
Bluegrass 7
The first thing you need to do is check the trans plug up.
The control leads may not be correct in the plug or the Trans socket between the 100 and the 70 trans plus a possible difference the year might make.
Both are electric operated in the same way but the correct solenoid leads addressd are verrrry important..
As well, the selector switch has to send a response back to the PCM that matches the gear mode selected on a 3 lead combination so the PCM knows what to do for up and down shifting vs throttle position and vehichle speed.. Don't forget Neutral and Park starting positions for the starter.circuit. Reverse doesnot requie any solenoid signal per say except the Pressure contol valve because its a mechanical one gear position.
Example in Binay code.
Gear 1 would be a 100.
Gear 2 would be a 010.
Gear 3 would be a 110
How this counts:
Digit position 1 = 1
Position 2 = 2.
Position 3 = 4.
For gear 3 example, add position values 1 and 2 togather make a 3= third gear.
The PCM is digital and interpet the signals in this manner.. The PCM does not handle Decimal numbers directly but must be converted by A/D chip conversion.
Sorry, it's not just a one lead signal because diagnostic monitoring has to be involved in it's original application.
So check that the address leads match at the transmission to at least operate the correct internal solenoids.
If the PCM cannot monitor the operation, you have no way to know a malfunction unless drivabiolity becomes an issue, even then you may not know what operatinal circuit is in trouble.
If this becomes a big problem, consider going backwards to an AOD that would bolt up to the 5.4.
This trans is not electriclly operated but requires a throttle cable to adjust pump pressure.
The shifting is via mostly a centrifical fly weight in the trans that provided fluid flow routing in the valve body after the selector switch is put in gear..
You have some study to do over all this first.
If none of this is helpful, there is alway manual shift 4, 5 or 6 speed but needs a flyweel and clutch/pedal setup.
Good luck.
Old Jul 14, 2020 | 11:39 PM
MSgtling's Avatar
MSgtling
Thanks for the response BlueGrass, however, none of what you said addresses me issue. I simply need an ECM from a 1999 Ford that had the 5.4SOHC motor and 4R70W tranny. The wiring is already installed custom for this application from Ron Francis. What I need to know is this.
1. What 1999 vehicles can i find the correct combo
2. Is there a way to ensure the ECM I pick up is for that combo...IE a part number or something.
The ECM I have is hard coded for the 5.4 with a 4R100 so it will not work according to Ron Francis. All I need is the correct ECM and they will code their chip for PATS and emissions removal.
Old Jul 15, 2020 | 10:02 AM
Stonedpony's Avatar
Stonedpony
Originally Posted by MSgtling
Thanks for the response BlueGrass, however, none of what you said addresses me the issue. I simply need an ECM from a 1999 Ford that had the 5.4SOHC motor and 4R70W tranny. The wiring is already installed custom for this application from Ron Francis. What I need to know is this.
1. What 1999 vehicles can I find the correct combo
The ECM I have is hardcoded for the 5.4 with a 4R100 so it will not work according to Ron Francis. All I need is the correct ECM and they will code their chip for PATS and emissions removal.
Just about any 1999 f150 with the 5.4 came with a 4r70w trans in a 4x4 as well as the 4.6, but the 4.6 got the PI engine just a little later than the 5.4. The expedition 97-00 came with the e40D and then the 4r100 was placed in them.
You can also check and order on eBay for one like you want for less than $100.00
Anyway here is an ECM MODULE P/N XL3F1-2A650-ARD
Also, this fits the 4.2L, & 4.6L, Lightning Standard Cab Pickup 2-Door 5.4L 330Cu. In. V8 GAS SOHC Supercharged,
All of these are 1999
2000 and up are different as well as 1997-98.
Anyway here are the ECM numbers for 1999 and I have not checked to see if they will fit all that year.
Someone did a lot of work to get all of these by the handle ibd2328
99 PCM CODES
Model Year Type Litres Part No Strategy Catch Code Hardware
F-SERIES MY99 ANY 4.2L XC3F-AAA RAAD3 LYT0 ML2-451
F-SERIES MY99 ANY 4.2L XC3F-ABA RAAD3 MCH0 ML2-451
F-SERIES MY99 ANY 4.2L XL3F-FB RBAEC AAT1 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-FC RBAED AAT2 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-FD RBAED AAT3 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-FE RBAEE AAT4 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-GB RBAEC BNC1 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-GC RBAED BNC2 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-GD RBAED BNC3 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-GE RBAEE BNC4 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-HB RBAED CVE1 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-HC RBAED CVE2 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-HD RBAEE CVE3 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-JB RBAEC DQE1 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-JC RBAED DQE2 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-JD RBAED DQE3 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-JE RBAEE DQE4 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-KB RBAEC EJK1 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-KC RBAED EJK2 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-KD RBAED EJK3 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-KE RBAEE EJK4 ML2-951
F-SERIES MY99 ANY 4.2L XL3F-LB RBAEC FMY1 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-LC RBAED FMY2 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-LD RBAED FMY3 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-LE RBAEE FMY4 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-MB RBAEC GTL1 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-MC RBAED GTL2 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-MD RBAED GTL3 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-ME RBAEE GTL4 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-NB RBAED HDP1 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-PB RBAEC JNY1 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-PC RBAED JNY2 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-PD RBAED JNY3 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-PE RBAEE JNY4 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-RB RBAEC KGA1 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-RC RBAED KGA2 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-RD RBAED KGA3 ML2-952
F-SERIES MY99 ANY 4.2L XL3F-RE RBAEE KGA4 ML2-952
F-SERIES MY99 ANY 4.6L XC3F-ACB RBAEC NSL1 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-ACC RBAED NSL2 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-ADB RBAEC PSA1 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-ADC RBAED PSA2 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-AEB RBAEC RCD1 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-AEC RBAED RCD2 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-AFB RBAEC SWY1 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-AFC RBAED SWY2 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-AGB RBAEC TPP1 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AGC RBAED TPP2 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AGD RBAED TPP3 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AHB RBAEC VTE1 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AHC RBAED VTE2 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AHD RBAED VTE3 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AJB RBAEC WXK1 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AJC RBAED WXK2 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AJD RBAED WXK3 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AKB RBAEC XTE1 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AKC RBAED XTE2 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-AKD RBAED XTE3 ML2-982
F-SERIES MY99 ANY 4.6L XC3F-CZA RBAED RPH0 ML2-981
F-SERIES MY99 ANY 4.6L XC3F-DAA RBAED SGX0 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-AAB RBAEC FUG1 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-AAC RBAED FUG2 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-AAD RBAED FUG3 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-ABB RBAEC GZW1 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-ABC RBAED GZW2 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-ABD RBAED GZW3 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-ADB RBAEC JHX1 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-ADC RBAED JHX2 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-ADD RBAED JHX3 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-AEB RBAEC KSR1 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-AEC RBAED KSR2 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-AED RBAED KSR3 ML2-982
F-SERIES MY99 ANY 4.6L XL3F-SB RBAEC YBQ1 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-SC RBAED YBQ2 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-SD RBAED YBQ3 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-TB RBAEC ZJP1 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-TC RBAED ZJP2 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-TD RBAED ZJP3 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-UB RBAEC AMG1 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-UC RBAED AMG2 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-XB RBAEC CFK1 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-XC RBAED CFK2 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-XD RBAED CFK3 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-YB RBAEC DRT1 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-YC RBAED DRT2 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-YD RBAED DRT3 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-ZB RBAEC EPY1 ML2-981
F-SERIES MY99 ANY 4.6L XL3F-ZC RBAED EPY2 ML2-981
F-SERIES MY99 ANY 4.6L XU7A-AHA RBAED PGC0 ML2-982
F-SERIES MY99 ANY 4.6L XU7A-AJA RBAED VMP0 ML2-982
F-SERIES MY99 ANY 4.6L XU7A-AKA RBAED TMC0 ML2-982
F-SERIES MY99 ANY 4.6L XU7A-ALA RBAED CTK0 ML2-982
F-SERIES MY99 ANY 4.6L XU7A-AMA RBAED HLW0 ML2-982
F-SERIES MY99 ANY 4.6L XU7A-ANA RBAED WSQ0 ML2-982
F-SERIES MY99 ANY 4.6L XU7A-APA RBAED CNJ0 ML2-982
F-SERIES MY99 ANY 4.6L XU7A-ARA RBAED WIR0 ML2-982
F-SERIES MY99 ANY 5.4L XC3F-ALB MBAI7 WIJ1 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-ALB MBAI7 WIJ1 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-ALC MBAI9 WIJ2 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-ALC MBAI9 WIJ2 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-ALD MBAIB WIJ3 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-ALD MBAIB WIJ3 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-ALE MBAIB WIJ4 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-ALE MBAIB WIJ4 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-AMB MBAI7 HNE1 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-AMB MBAI7 HNE1 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-AMC MBAI9 HNE2 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-AMC MBAI9 HNE2 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-AMD MBAIB HNE3 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-AMD MBAIB HNE3 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-AME MBAIB HNE4 MLC-481
F-SERIES MY99 ANY 5.4L XC3F-AME MBAIB HNE4 MLC-481A
F-SERIES MY99 ANY 5.4L XC3F-ARB MAAG4 MER1 MLC-421
F-SERIES MY99 ANY 5.4L XC3F-ARC MAAG4 MER2 MLC-421
F-SERIES MY99 ANY 5.4L XC3F-ARD MAAG4 MER3 MLC-421
F-SERIES MY99 ANY 5.4L XC3F-ARE MAAG4 MER4 MLC-421
F-SERIES MY99 ANY 5.4L XC3F-ASB MAAG4 NUY1 MLC-421
F-SERIES MY99 ANY 5.4L XC3F-ASC MAAG4 NUY2 MLC-421
F-SERIES MY99 ANY 5.4L XC3F-ASD MAAG4 NUY3 MLC-421
F-SERIES MY99 ANY 5.4L XC3F-ATB MAAG4 PIF1 MLC-422
F-SERIES MY99 ANY 5.4L XC3F-AUA MAAG2 REB0 MLC-422
F-SERIES MY99 ANY 5.4L XC3F-AUB MAAG4 REB1 MLC-422
F-SERIES MY99 ANY 5.4L XL3F-AFB RDABC BOJ1 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AFB RDABC BOJ1 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AFC RDABC BOJ2 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AFC RDABC BOJ2 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AFD RDABC BOJ3 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AFD RDABC BOJ3 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AFE RDABC BOJ4 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AFE RDABC BOJ4 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AFF RDABD BOJ5 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AFF RDABD BOJ5 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AGB MRAD2 CUX1 MLC-482
F-SERIES MY99 ANY 5.4L XL3F-AGB MRAD2 CUX1 MLC-482A
F-SERIES MY99 ANY 5.4L XL3F-AGC MRAD3 CUX2 MLC-482
F-SERIES MY99 ANY 5.4L XL3F-AGC MRAD3 CUX2 MLC-482A
F-SERIES MY99 ANY 5.4L XL3F-AHB MBAI7 DAH1 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AHB MBAI7 DAH1 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AHC MBAI9 DAH2 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AHC MBAI9 DAH2 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AHD MBAIB DAH3 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AHD MBAIB DAH3 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AHE MBAIB DAH4 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AHE MBAIB DAH4 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AKB MBAI7 FCR1 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AKB MBAI7 FCR1 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AKC MBAI9 FCR2 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AKC MBAI9 FCR2 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AKD MBAIB FCR3 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AKD MBAIB FCR3 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-AKE MBAIB FCR4 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-AKE MBAIB FCR4 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-ARB RDABB ZZT1 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-ARB RDABB ZZT1 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-ARC RDABC ZZT2 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-ARC RDABC ZZT2 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-ARD RDABC ZZT3 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-ARD RDABC ZZT3 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-ARE RDABC ZZT4 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-ARE RDABC ZZT4 MLC-481A
F-SERIES MY99 ANY 5.4L XL3F-ARF RDABD ZZT5 MLC-481
F-SERIES MY99 ANY 5.4L XL3F-ARF RDABD ZZT5 MLC-481A
F-SERIES MY99 ANY 6.8L XC3F-AVB MAAG4 YHH1 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-AVC MAAG4 YHH2 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-AXA MAAG2 ZAY0 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-AYB MAAG4 AEO1 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-AYC MAAG4 AEO2 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-AZB MAAG4 BIH1 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-AZC MAAG4 BIH2 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-AZD MAAG4 BIH3 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BBB MAAG4 DOZ1 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BBC MAAG4 DOZ2 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BBD MAAG4 DOZ3 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BCB MAAG4 EAP1 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BCC MAAG4 EAP2 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BCD MAAG4 EAP3 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BDB MAAG4 FOT1 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BDC MAAG4 FOT2 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BDD MAAG4 FOT3 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BDE MAAG4 FOT4 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BGB MAAG4 JUR1 MTC-301
F-SERIES MY99 ANY 6.8L XC3F-BGC MAAG4 JUR2 MTC-301
Old Jul 15, 2020 | 03:09 PM
MSgtling's Avatar
MSgtling
Stonedpony,
I can't thank you enough. The information you provided set me on a path that resulted in ordering an ECM I am confident will fix my issue. THANK YOU!
Old Jul 17, 2020 | 03:15 PM
Stonedpony's Avatar
Stonedpony
Sorry for the late reply, ut you are more than welcome.
truckerlife
Oct 10, 2018 11:00 AM
rustfarmer
43
May 20, 2009 01:38 AM
66f14evr
Engine Swaps
Jul 5, 2005 10:57 AM
lariatrider
Engine Swaps
Jul 3, 2004 09:13 AM
trucksforever
Dec 18, 2003 02:14 PM
