Exhaust system replacement
Old Jul 13, 2020 | 10:05 PM
Thistle97's Avatar
Thistle97
Question Exhaust system replacement
Where can I find instructions/video for replacing my exhaust system? I don’t need a Catalytic Converter, it was removed years ago by the previous owner. I have a 5.8 94 F250. Any input is welcome as this is my first time replacing an exhaust.
Old Jul 14, 2020 | 07:47 AM
jas88's Avatar
jas88
Have you searched youtube?
Old Jul 14, 2020 | 07:51 AM
Thistle97's Avatar
Thistle97
Yes but I haven't found the right year range and type of truck.
Old Jul 14, 2020 | 09:20 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Unbolt (if you can) or cut it off. You will need to get the old intermediate pipe off the end of the catalytic converter. Do not cut the end of the converter. Install new parts.
The pipes are slip fit. Install new clamps. It’s pretty self explanatory.
Old Jul 14, 2020 | 02:19 PM
Thistle97's Avatar
Thistle97
Thank you! I don't actually have a converter, the previous owner removed it.
Old Jul 14, 2020 | 04:42 PM
jas88's Avatar
jas88
It's all about the same you don't have to find one for your exact year and model of truck.
Old Jul 14, 2020 | 06:37 PM
kevinv10's Avatar
kevinv10
Do you have to block off air injection to manifolds or head? If not, or already done, as previous poster said pretty much follow any video. Relatively easy to do.
Old Jul 20, 2020 | 04:05 PM
Hyperhad's Avatar
Hyperhad
I don't know if this would be the same but I have your same truck just a 1997 I only put on performance exhaust manifolds but all you do is unbolt the manifolds from the heads, remove the bolts holding the manifold to the rest of the exhaust pipes (two each side) and then I believe you remve one 02 sensor. Hope this helps!
Old Jul 22, 2020 | 10:30 AM
jackietreehorn's Avatar
jackietreehorn
What would you like to know? I just did this last Sunday.
the_auto_tech
Mar 25, 2013 09:18 PM
Astrowing
Jul 14, 2009 10:11 PM
