engine tranny seperation
help guys
When I pulled my 302, had the same trouble. I ended up removing the timimg cover and all the extraneous equipment from the front of the engine to make room enough so I could slide the engine forward far enough to slip the torque converter off the front splines. Once on the engine stand, the converter nuts were still a PITA and I ended up splitting them and replacing them. When the new 302 went in, I installed the converter back into the bell housing first then rebolted the flywheel once the engine was in the truck. You have to take care not to cut the inner seal on the converter when you reinstall it but its makes for a lot fewer headaches if you can reinstall the converter first. Trying to line up the guide pins and bolt holes between engine and tranny is difficult enough without having to deal with torque converter splines as well.
If you pull the converter out with the flexplate, just make sure you drain it as good as you can. Otherwise there'll be an ATF flood.
Mine's a '92, I wonder if they used some sort of jam nut on your year.
any more help you can give guys is appreciated this is no fun doing this by yourself.
late
Glad to hear you were able to get the flexplate and TC seperated. No, no need to pull the converter if you don't have to. Will save you from having to clean up the puddle of tranny fluid too.
1pump,
Mine was a 92 and no corrosion here either...just wouldn't budge. They are all lock nuts the kind that are "pinched" on three sides to create drag when run down the bolt or stud.
I am just glad to hear I'm not the only one to have had that difficulty.
