Check Engine Light- EGR Problem.
Old Jan 5, 2001 | 09:07 AM
Katt's Avatar
Katt
Greetings, I get a code 31 and 32 on my 1988 F150 351W. The thing is, the engine light will go out during acceleration, and come back on when I let off the gas. Is this a problem with the vaacum or what?
Thanks much for your help!
Old Jan 5, 2001 | 07:25 PM
trouble's Avatar
trouble
Check to make sure your EGR valve is opening and closing , also check vacuum to it . From my experience it sound as if you need a new EGR Valve about $130.00in my area and its a dealer item.
Trouble
Old Jan 7, 2001 | 10:26 AM
bill russis's Avatar
bill russis
Napa has the EGR valves and some of the other sensors also..
Old Jan 9, 2001 | 12:24 AM
charlez's Avatar
charlez
Old Jan 11, 2001 | 10:00 PM
claymac69's Avatar
claymac69
Sometimes turning the key to the "on" position and then off 3 times in a row will reset the comp... its a quick easy try that can't ##### nothing up.
1980 F100, 300 I6, 2wd, 3spd w/overdrive, two tone green bottom with off white top, no rust, dents, scratches. diamond plate bed rails, diamond plate toolbox, diamond plate tailgate protector, air shocks, pioneer CDplayer with 2way boxed 6x9's behind the seat, and 3 way 4" in the doors. FUTURE PLANS: New rims, fix a/c,
jerrysrios
Electrical Systems/Wiring
91
Feb 18, 2025 03:12 PM
Jimmypritchett
Dec 12, 2016 10:25 PM
mike
16
Jan 7, 2016 09:56 PM
brucememp
13
Dec 28, 2004 02:00 PM
downhomegirl2
Escape & Escape Hybrid
Feb 22, 2004 11:06 AM
