Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Decode requests
Old May 19, 2020 | 08:58 PM
Jficek's Avatar
Jficek
f61dk802686. Help with the decode thanks
Old Jun 26, 2020 | 11:37 AM
MichaelVF600's Avatar
MichaelVF600
I hear you are the wizard with decoding VIN's. Can you lend a hand on the F600 I recently picked up? F61EVY41769. Thanks in advance for any help!
Old Jul 12, 2020 | 06:51 PM
85e150's Avatar
85e150
These posts were unanswered in the old decode thread.
Our regular decode member has taken up other interests. (But may be back from time to time.....)
https://www.ford-trucks.com/forums/1...ruck-info.html
There are still members here who decode from time to time.
Rather than close these off, I wanted to leave these open in case one of other folks could help.
Old Jul 14, 2020 | 04:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Notmeofficer
Rubber auxiliary steering shaft rod end boot
1979 Ford F600 4 x 4
This is the boot that goes on the end of the steering shaft that powers the right side axle
It has the numbers "18-1 AB-15" on it
Google doesnt list anything.. Ill probably have to fabricate one
Manual or Power Steering?
Old Jul 14, 2020 | 04:43 PM
NumberDummy
Originally Posted by HDSS250
I am new to the forum. I am considering buying a 1976 Ford L9000. VIN is K90TVC18432.
I believe this means:
K90: L900 (Diesel). L9000 is an L900 w/a diesel engine.
T: Detroit Diesel 8V92TA
V: Kentucky Plant
C18432: 1976
Correct?
It is now...
Old Jul 14, 2020 | 04:50 PM
NumberDummy
Originally Posted by Mexibilly
Ok will do. I posted on one thread and it got moved. I’m new on here. I plan on maybe stretching it out a few inches and go from there. Always wanted one.
IF the last 6 digits of the VIN are C70167, this is a 1967, not a 1968. Warranty Plate is filthy, very hard to read.
Old Jul 14, 2020 | 04:56 PM
85e150's Avatar
85e150
194
W952
816W (W?)
D4G
49000
225
2100
38005
Old Jul 14, 2020 | 05:46 PM
NumberDummy
I just bought my first NT950 and have been trying to decode the Warranty Plate.
W95 = NT950 Diesel. The T refers to tandem axles.
2 = Detroit model 6-71N 6 Cylinder 426 cid Diesel.
U = Louisville KY Assembly Plant.
C70167 = 1967.
194" Wheelbase.
COLOR code = Blank, truck painted a non standard color, making it a Domestic Special Order.
W952 = NT950 Diesel, 49,000 lbs. GVWR
4 81 (6W is the TRANS code) // 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl // 81 = 81A Standard Cab.
6W = Dana/Spicer model 6352-B 5 Speed Direct.
D4G:
D4 = Timken model SQHDA Forward Rear & Timken model SQHDR Rear Rear / 5.29-1 / 38,000 lbs. Axle Capacity.
G = Rockwell/Timken model FF-903 12,000 lbs. Capacity Front Axle without Center Point Steering.
49,000 lbs. Gross Vehicle Weight Rating.
225 net HP @ 2,100 RPM
380005:
38 = Pittsburgh PA Ford District Sales Office, where the original selling dealer ordered the truck from.
0005 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
Post #22: Thanks for the help, Ed. One can blow the pic up, but when one has nearly 76 year old eyes, that may not help.
Old Jul 16, 2020 | 04:41 AM
Mexibilly's Avatar
Mexibilly
C70167 = 1967.
194" Wheelbase.
D4G:
380005:
Thank you so much. I really do appreciate your help.
Tripper68
Jul 14, 2020 04:55 PM
xRogerDabbitx
Large Truck
Sep 16, 2018 11:10 PM
No More Raptor
29
Sep 16, 2013 11:10 AM
JIM ROLAND
13
Jan 4, 2008 05:28 AM
