Aerostar Ford Aerostar
High pitched vacuum leak
Old Jul 11, 2020 | 12:02 AM
TheSmallPPClub's Avatar
TheSmallPPClub
1997 aerostar 4.0 xlt awd
I have a really high pitched vacuum leak coming from the egr valve area. To confirm it was egr related, I pulled the codes and it stated "egr gasket leak". Has anyone had to deal with this, could it possibly be the valve itself causing that high pitched leak? I had a few other codes pulled, "dirty maf, exhaust leak, etc, etc.) Cleaned the maf and the idle is marginally better.
Anyone have any suggestions? Im thinking it could just be a bad egr valve gasket, or possibly pcv valve.
Old Jul 11, 2020 | 02:08 AM
xlt4wd90's Avatar
xlt4wd90
If the EGR valve has a plastic vacuum nipple, especially if it is a 90 degree angle version, it could have cracked. That could present a whistling leak.
Old Jul 17, 2020 | 03:29 AM
TheSmallPPClub
Looked over the egr vacuum lines, thankfully nothing was wrong there. However I did discover that the vacuum hose coming off the throttle body had disintegrated. Thanks for your help man
Longh
Sep 27, 2018 10:11 AM
n5926g
1997 - 2003 F150
Feb 7, 2009 08:15 AM
870
Aug 14, 2008 02:31 PM
billman
May 27, 2003 05:24 PM
vls
Feb 7, 2003 05:16 AM
