Engine HELP
Old Oct 19, 2003 | 12:09 PM
51truck's Avatar
51truck
Engine HELP
Installed new cam, lifters, roller rockers, valve springs in 351w. Cam is a extreme energy 262 by comp cams. I have a squeek that I cant find starts at 3000 rpm and get louder as you decrease idle, and quits at idel. I took off belt and its still does it. Could I have gotten bad rockers and it the rollers squeeking? What could this be? Also headers are getting red hot what causes this my timing is at 6 deg btc. Thanks for you input.
Old Oct 19, 2003 | 12:19 PM
TorqueKing's Avatar
TorqueKing
Your timing is too late for one thing, move it up to at least 10. Do that first, I beleive that will stop your extreme exhaust temperature.
Old Oct 19, 2003 | 04:06 PM
Justme's Avatar
Justme
Do you only have one belt? Does your engine have any idler pulleys on it? Dont forget your A/C Compressor's pulley has an idler pulley bearing in it.
Alternators, Water Pumps, and idler pulley bearings will pick the craziest of times to bo bad: after disturbing them during a cam swap/engine build-whatever, the alternator, water pump, and Idler Pulley Bearings will sometimes decide to give up the ghost(?).
Disconnect ALL belts-then turn both the alt & water pump by hand. You will want to notice any friction while turning their pulleys by hand.
While ALL of the belts are off you may wish to start it up and listen for a few seconds: not to be ran more than 20-30 seconds at a time. If you still hear the noise then your problem is not w/your belts or accessories.
Kevin,
Old Oct 19, 2003 | 05:49 PM
51truck's Avatar
51truck
I only have one belt, I took it off and it still had the noise. Could a roller rocker make this kind of noise it sounds just like a belt squeeking.
Old Oct 19, 2003 | 09:23 PM
macguyver's Avatar
macguyver
If the timing is retarded to the point the combustion process isn't completed when the exhaust opens, the squeek you hear might be those gasses escaping into the exhaust. It would also cause the headers to get excessively hot.
Shadow944795
May 22, 2015 01:23 PM
SoCalAngler
May 8, 2015 08:42 AM
old farmer
Oct 5, 2014 04:45 PM
scottmt
New Member Introductions
Oct 11, 2006 04:29 PM
armyman
Nov 1, 2004 11:01 AM
