2019 F350 Left Pull
Old Jul 9, 2020 | 05:09 PM
jstadler's Avatar
jstadler
2019 F350 Left Pull
I have a new dually that pulls to the lift when in the left lane. It does not pull in the right lane. I have had it aligned by two companies and it's well within specs. The dealer said it's following the crown of the road. The SAI Included angel is off 3 degrees from left to right with the low of 16 on the left and high of 19 on the right. Any thoughts why my truck pulls to the left hard when in the left lane?
Thank you
John Stadler
Old Jul 9, 2020 | 09:00 PM
cat-alac's Avatar
cat-alac
Had a 17,18,19 srw 350 all were good my 2020 if left lane would hit the ditch on 7-8 seconds if I let the wheel go, same thing took in for alignment did not improve must be something with castor?? I run about 3-4 psi less in right tires helps a bit.
Old Jul 10, 2020 | 03:55 PM
speakerfritz's Avatar
speakerfritz
how much do you weight?
if you weight 600lbs dealer is right
if you weight 200lbs..find another service department.
Faceplant409
Jan 13, 2019 07:50 AM
bliggity
Jul 3, 2018 11:44 PM
speakerfritz
May 7, 2018 11:26 AM
LaredoF350
Feb 21, 2008 06:30 PM
